Tailshift rear cover, Fitment issue |
MM1 |
May 22 2022, 06:26 PM
914 obsession continues Group: Members Posts: 608 Joined: 9-May 18 From: Thousand Oaks, CA Member No.: 22,105 Region Association: Southern California |
Am I missing something here?
I just bought this new tailshift rear cover from Sierra Madre-it is an Uro part. It doesn’t appear to be properly designed-but I could be wrong since I have never seen one before nor have I ever tried to install one (i.e. perhaps I am not doing something correctly but another ‘Teener thought the cover was incorrect), so any advice would be much appreciated. The seventh (Second to last picture) posted here is upside down(sorry-I’m not going to blow 15 minutes more trying to fix that). Nonetheless, all the pictures show that the cover is pushed all the way on to the mounting bracket so that even if we trimmed very end of the round portion, that would not allow the cover to be moved forward, since the area where the round portions of the cover pinch in to a smaller diameter would never clear the end of the round metal surround that holds the bushing. The result of all this, as you can see in the other pictures, is that cut out for the tailshift Rod is not in the correct position to close the new cover. The last picture shows the cover with the round portion fully seated against the bushing bracket-but the cut out for the rod is still too far rearward to close the cover-much less to seal it and keep out the dirt. Attached image(s) |
mgphoto |
May 22 2022, 06:37 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
The cover fits over the cup holding the bushing, a hose clamp holds the cover in place and an o ring holds it closed at the rear.
Mikey914 |
May 23 2022, 02:56 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
SO does it actually fit? We had looked at making these, but with these being available cheaply we opted not to.
aturboman |
May 23 2022, 02:20 PM
Member Group: Members Posts: 135 Joined: 18-October 11 From: CA Member No.: 13,687 Region Association: None |
914-4 and 914-6 take different rear covers.
The 4 cyl trans has a different transmission bushing bracket off-set and thus the covers look similar but will not interchange. |
dr914@autoatlanta.com |
May 23 2022, 03:10 PM
914 Guru Group: Members Posts: 7,896 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
there are two the four and the six, the six is much bigger than the four
Am I missing something here? I just bought this new tailshift rear cover from Sierra Madre-it is an Uro part. It doesn’t appear to be properly designed-but I could be wrong since I have never seen one before nor have I ever tried to install one (i.e. perhaps I am not doing something correctly but another ‘Teener thought the cover was incorrect), so any advice would be much appreciated. The seventh (Second to last picture) posted here is upside down(sorry-I’m not going to blow 15 minutes more trying to fix that). Nonetheless, all the pictures show that the cover is pushed all the way on to the mounting bracket so that even if we trimmed very end of the round portion, that would not allow the cover to be moved forward, since the area where the round portions of the cover pinch in to a smaller diameter would never clear the end of the round metal surround that holds the bushing. The result of all this, as you can see in the other pictures, is that cut out for the tailshift Rod is not in the correct position to close the new cover. The last picture shows the cover with the round portion fully seated against the bushing bracket-but the cut out for the rod is still too far rearward to close the cover-much less to seal it and keep out the dirt. |
gandalf_025 |
May 23 2022, 03:46 PM
Senior Member Group: Members Posts: 1,456 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States |
MM1 |
May 24 2022, 02:16 PM
Ok- after speaking with Sierra Madre it’s clear.
This cover is for a 914-6. So no, Mark - it does not actually work For my 4. George - As far as I can tell , your website only lists a 914–6 cover as well - is the 914–4 rear cover for a tail shifter NLA ? I have not been able to find one on eBay or any other venue. If anyone has one that fits a four that I can purchase please let me know as soon as possible. I appreciate your support as always . Mark- is it possible for you to start a run after you create all new tooling this week ? - lol. (IMG:style_emoticons/default/sad.gif) On a different note the firewall bushing that I bought from Auto Atlanta has made the shifting so incredibly tight and difficult it is quite hard to believe that it will wear enough to loosen up. @Robarabian helped me (actually he taught me while I mostly watched- thank you,Sir!) said the 914Rubber one he used in his tailshifter went in easy and was not to tight. Granted- this is a back date and I have no original tail shifter to measure against - but the installation looks as well done as possible ( except there is no lip on the firewall for me to mount the cover too), and the previous owner told me that in it’s past life it shifted well - at least well enough for a tail shifter. I will say that even though I cannot start the car right now it appears to be grabbing all the gears even with the Weltmeister short shifter that was previously installed - it is just so very tight . After freezing the short rod etc.(didn’t work- even with the hammer (IMG:style_emoticons/default/blink.gif) ) we ultimately had to pry it in with a 4 x 6 and a pry bar. Do you think shifting will wear the bushing out enough to make it more manageable fairly quickly or would that take quite some time? We used Lucas white lithium grease on all the bushings. I guess the good news is that at the moment, surely I have the tightest shifting tail shifter of all time. Of course whether or not it will actually shift after I get the car running is another matter. |
MM1 |
May 27 2022, 01:51 PM
So no luck on my WTB post for a 914-4 rear tailshift cover. . .do you think I should just mod this $45 new cover that doesn’t fit (if possible)?
Any suggestions or alternatives? |
Lo-Fi Version | Time is now: 9th June 2024 - 05:44 PM |
