| ctc911ctc |
May 29 2022, 11:03 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,266 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
'74 2.0 - around 25K, all original
Well, I thought this would go back together simply, not a chance - so I have a few questions. 1. TAB WASHER - does this do anything? If it is intended to do anything, why do I find pictures of this thing UN-LOADED, or the tabs bending downward NOT upward. I installed this with the tabs upward, took some pressure to get the cotter pin into the holes......this seems correct, any thoughts? Also, does it really do anything? Really? (IMG:style_emoticons/default/confused24.gif) ![]() 2. Threaded Pin - I tried to get this thing in and it does not fit. Looking at the picture I bought ball-joints for up to '72! HOWEVER, the ball joints I purchased on the BirdSite are specified to fit on a '74. They do fit. HOWEVER, the Threaded pin does not. To make this MORE interesting, the AutoAtlanta website description details that their theaded pin is for '72 and later......... (IMG:style_emoticons/default/confused24.gif) QUESTION: Do I buy an older theaded pin? Do I grind the marks on the one I have to make it fit? NOTE: there are two marks from where the pin is meeting the curve of the ball joint..... (IMG:style_emoticons/default/blink.gif) ![]() I SHOULD HAVE POWDER COATED EVERYTHING! (IMG:style_emoticons/default/headbang.gif) ![]() Attached image(s)
| Shivers |
May 29 2022, 11:10 AM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,158 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Those ball joints may be for the pinch bolts 68-71
| 914werke |
May 29 2022, 11:14 AM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,444 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
The lock plate works by bending the tabs up into the machined slots.
There are two (2) main types of strut housing, early/late with corresponding ball joints & hardware. Your 74 should have LATE unless a PO changed it out for some reason The Pin in your image is for a late strut/ball joint combo. The Ball joint is for early You need the right ball joints |
| Literati914 |
May 29 2022, 11:23 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,124 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
[/quote]…there are two marks from where the pin is meeting the curve of the ball joint..... (IMG:style_emoticons/default/blink.gif)
[/quote] If the ball joints that you purchased have a “curve” where you think the pin runs thru, then you have the wrong ball joints. The pin type ball joints will have more of a “V” shaped recess to accept the pin (which is of an angular nature, not round). If you’re setup was already using the angular pin, the you need the matching ball joints. The pin set up is later ball joints. Ball joints with a curved recess are designed for the “pinch bolt” earlier style struts (which have a small vertical cut/gap at the bottom tip of the strut). . |
| ctc911ctc |
May 29 2022, 01:06 PM
Thank you for the assistance - YES, I ordered the wrong part - HOWEVER- I am pretty certain that I selected the RIGHT part. Wen through the waterfall selection - Porche -> 74 -> 914 -> 2.0 .....etc,,,,,
It was fulfilled through Rennlist THOUGH the part is packaged by Pelican......yow,,,,, QUESTION - Everything fits perfectly with the exception of the threaded bolt, is there a 70/71 bolt that would fit? is the V the only difference? This seems to be the setup, though the bolt looks like a V and the Ball Joint has a rounded NOT V Shaft............intersting. ![]() |
| 914werke |
May 29 2022, 01:30 PM
"The Ball joint is for early You need the right ball joints" (IMG:style_emoticons/default/confused24.gif) |
| rhodyguy |
May 29 2022, 01:48 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
The fastener should not stick out of the strut as in the first picture. Do not attempt to draw the correct V shaped bolt in with a ratchet. Good chance you'll twist it off. Then you're dead in the water until the replacement arrives. Drive it in with a smooth faced hammer and use a torque wrench to tighten the nut.
| Literati914 |
May 29 2022, 02:36 PM
.. QUESTION - …, is there a 70/71 bolt that would fit? is the V the only difference? No a bolt of any kind would not work, because as I mentioned, there is a cut/gap at the bottom tip of early struts (which you don’t have) - that gap is crucial for proper clamping. Apparently that set up would occasionally oval out the hole (that the ball joint fits in), so Porsche upgraded to the wedge pin design (that you have). . |
| mepstein |
May 29 2022, 02:56 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,202 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
If your ball joint has a semi circle it’s early and DOES NOT WORK with the wedge pin. Don’t try it. Don’t hammer it. Don’t tighten it or grind it.
The semi circle ball joint works with a pinch bolt strut. Vertical slit at bottom of strut. The wedge type ball joint works with a pin type strut. No vertical slit or gap on the bottom of the strut body. Regardless of what the pelican parts catalog says (it’s not always right) the above is all that matters. The description on label is completely wrong for that pin. Attached image(s)
| mepstein |
May 29 2022, 02:59 PM
.. QUESTION - …, is there a 70/71 bolt that would fit? is the V the only difference? No a bolt of any kind would not work, because as I mentioned, there is a cut/gap at the bottom tip of early struts (which you don’t have) - that gap is crucial for proper clamping. Apparently that set up would occasionally oval out the hole (that the ball joint fits in), so Porsche upgraded to the wedge pin design (that you have). The pinch bolt struts work fine unless the pinch bolt loosens and the car continues to get driven. Once it’s loose, it moves around and wallows out the hole. Then it’s pretty much ruined. |
| Superhawk996 |
May 29 2022, 03:08 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,501 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Swap to proper late - wedge ball joints.
Suspension is not the place for jury rigging. I'd then take up a return authorization with the folks that sold you the wrong parts since you appear to have done the drill down for 74' (late) parts yet they sent you early parts. |
Lo-Fi Version | Time is now: 4th November 2025 - 08:43 PM |
