Distributor? |
Distributor? |
Boothy |
Jun 1 2022, 12:13 PM
Member Group: Members Posts: 88 Joined: 17-January 19 From: Abington, MA Member No.: 22,805 Region Association: North East States |
Folks,
Happy almost summer! I'm FINALLY ready to put the engine back in and looking at the distributor. I have a 1.7 with a big bore kit, cam, balanced crank, Webers. I have the old distributor with the FI. Should I use that? Get a Mallory? I went through the Pertronix experience with another car. Ended up being such a pain that I ripped it out and went back to an 009. Thanks in advance for your thoughts! |
914sgofast2 |
Jun 1 2022, 12:58 PM
Senior Member Group: Members Posts: 623 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
The only way to go these days is with a new 123Distributor with programable advance curves. You will probably gain horsepower and drive-ability over using the old FI Djet dizzy or the dreaded 009 dizzy.
mobymutt |
Jun 1 2022, 01:33 PM
Senior Member Group: Members Posts: 550 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada |
The only way to go these days is with a new 123Distributor with programable advance curves. You will probably gain horsepower and drive-ability over using the old FI Djet dizzy or the dreaded 009 dizzy. I agree 100%! Finally got mine installed last year, and it's so much easier to set up and tune, and then basically no maintenance. |
Chaznaster |
Jun 1 2022, 05:45 PM
Member Group: Members Posts: 305 Joined: 22-November 15 From: Concord, MA Member No.: 19,389 Region Association: North East States |
The only way to go these days is with a new 123Distributor with programable advance curves. You will probably gain horsepower and drive-ability over using the old FI Djet dizzy or the dreaded 009 dizzy. (IMG:style_emoticons/default/agree.gif) |
Boothy |
Jun 2 2022, 05:32 AM
Thanks all! Never thought I'd spend that much on a dizzy but I am looking for an easier life. So where you're programming your advance you go without vacuum and plug the port on the carb? I see the Porsche 912 / 914 / 356 / VW 411E / 412E / 1600E 123ignition Distributor Switched W/O Vacuum Includes Spacer For my own education, is the Type 1 dizzy physically different from the Type 4? I see some have had to modify tin but... |
Lo-Fi Version | Time is now: 9th June 2024 - 09:26 PM |
