fuel pump selection, 914 1.7 webers |
Tewfiks |
Jun 11 2022, 07:24 PM
Newbie Group: Members Posts: 5 Joined: 23-March 22 From: Florida Member No.: 26,416 Region Association: South East States |
Hello, I am still sorting out our 1973 914 1.7L. The fuel pump is seized up and I can not find a cross reference for a proper replacement. The pump that failed is a Carter 4K17A. I can not find any information on this pump. I assume the webers need 3 psi fuel delivery to run well. I have found a low pressure Bosch unit at parts geek but hesitate to purchase until I get suggestions from others on this forum.
Any suggestions/recommendations? Thanks |
mate914 |
Jun 12 2022, 09:48 AM
Matt Group: Members Posts: 753 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States |
I have used this one from CB performance."3193 Rotary Fuel Pump"
Matt (IMG:style_emoticons/default/flag.gif) Hello, I am still sorting out our 1973 914 1.7L. The fuel pump is seized up and I can not find a cross reference for a proper replacement. The pump that failed is a Carter 4K17A. I can not find any information on this pump. I assume the webers need 3 psi fuel delivery to run well. I have found a low pressure Bosch unit at parts geek but hesitate to purchase until I get suggestions from others on this forum. Any suggestions/recommendations? Thanks |
mmichalik |
Jun 12 2022, 09:53 AM
MikeM Group: Members Posts: 700 Joined: 27-January 16 From: Valley Center, CA Member No.: 19,600 Region Association: Southern California |
I have used this one from CB performance."3193 Rotary Fuel Pump" Matt (IMG:style_emoticons/default/flag.gif) (IMG:style_emoticons/default/agree.gif) that's the way to go |
CG-914 |
Jun 12 2022, 03:47 PM
Member Group: Members Posts: 326 Joined: 27-December 10 From: LA/OC CA Member No.: 12,526 Region Association: Southern California |
Another great high quality option is the Pierburg 7.21440.51.0
porschetub |
Jun 12 2022, 04:15 PM
Advanced Member Group: Members Posts: 4,703 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
[quote name='mate914' date='Jun 13 2022, 03:48 AM' post='3008148']
I have used this one from CB performance."3193 Rotary Fuel Pump" Matt (IMG:style_emoticons/default/flag.gif) [quote name='Tewfiks' post='3008057' date='Jun 11 2022, 09:24 PM'] Hello, I am still sorting out our 1973 914 1.7L. The fuel pump is seized up and I can not find a cross reference for a proper replacement. The pump that failed is a Carter 4K17A. I can not find any information on this pump. I assume the webers need 3 psi fuel delivery to run well. I have found a low pressure Bosch unit at parts geek but hesitate to purchase until I get suggestions from others on this forum. Any suggestions/recommendations? Thanks [/quote] (IMG:style_emoticons/default/agree.gif) only one to use,seem to remember the CB Performance one is in fact a Carter pump anyway,if you buy as a Carter it's actually cheaper than the CB one,I use a regulator (Holley LP ) and 7.5 amp fuse with mine,mounted on the steering rack it is fairly quiet but still enough to hear when its running. |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:47 AM |
