Tbrown4x4 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 707 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None ![]() ![]() |
I have a set of engine tins that have a plastic tube attached to a square hole in the driver’s side rear. What years does this fit? The parts manual says WO engine if I read it correctly.
Attached image(s) ![]() ![]() ![]() ![]() |
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,248 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
early 1.7 with oil bath air filter.
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,240 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
Do a WTB for a later set of 1.8 upper tin. That set you have might be of some value to a person needing that specific style.
L-Jet914 |
Member ![]() ![]() Group: Members Posts: 340 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California ![]() |
As stated above the engine tin is for a 1.7 with a thermostatic air cleaner assembly. All for early emissions controls to help get the intake temperatures up quicker to allow for better fuel atomization. When the temperature reached a certain point usually a bi-metallic spring would shut off flow from that pipe and start pulling "fresh cooler air."
Tbrown4x4 |
Thanks everyone. It must be the original stuff for my 71 parts car.
Garland |
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,411 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest ![]() ![]() |
“I have a set of engine tins that have a plastic tube attached to a square hole in the driver’s side rear. What years does this fit? The parts manual says WO engine if I read it correctly.“
That’s specific to 72-1.7 |
Lo-Fi Version | Time is now: 9th May 2025 - 12:00 PM |
