Tbrown4x4
Jun 21 2022, 05:47 PM
I have a set of engine tins that have a plastic tube attached to a square hole in the driver’s side rear. What years does this fit? The parts manual says WO engine if I read it correctly.
914werke
Jun 21 2022, 06:44 PM
early 1.7 with oil bath air filter.
rhodyguy
Jun 22 2022, 07:44 AM
Do a WTB for a later set of 1.8 upper tin. That set you have might be of some value to a person needing that specific style.
L-Jet914
Jun 25 2022, 07:26 PM
As stated above the engine tin is for a 1.7 with a thermostatic air cleaner assembly. All for early emissions controls to help get the intake temperatures up quicker to allow for better fuel atomization. When the temperature reached a certain point usually a bi-metallic spring would shut off flow from that pipe and start pulling "fresh cooler air."
Tbrown4x4
Jul 1 2022, 11:58 PM
Thanks everyone. It must be the original stuff for my 71 parts car.
Garland
Feb 27 2023, 01:14 PM
“I have a set of engine tins that have a plastic tube attached to a square hole in the driver’s side rear. What years does this fit? The parts manual says WO engine if I read it correctly.“
That’s specific to 72-1.7
