rosenfe |
Senior Member ![]() ![]() ![]() Group: Members Posts: 561 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None ![]() |
I have a stripped shift bar cone screw. I bought a spiral screw extractor. Bit and extractor in kit. Do I drill clockwise? What direction to turn extractor?
GeorgeKopf |
Member ![]() ![]() Group: Members Posts: 172 Joined: 9-February 21 From: Princeton, NJ Member No.: 25,186 Region Association: MidAtlantic Region ![]() |
Drill a hole as normal. Try to get it as centered as possible (this can be tricky).
I'm assuming that the head broke off because it is rusted solid. Use PB Blaster or Liquid Wrench and let is soak. Apply some heat too if you can. Then put the extractor bit in your drill and run it in reverse (extraction direction). Go slow and put a lot of downward pressure to get the edges of the bit to bite into the metal. Once the screw starts to move, keep going and it will unscrew itself. Good Luck George |
rosenfe |
The Allen head stripped.
914 RZ-1 |
Porsche Padawan ![]() ![]() ![]() Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California ![]() |
I have had nothing but bad luck with screw extractors. They usually break off in the hole I drill. I usually end up drilling a hole thru the broken bolt bigger and bigger until I can get the pieces out.
You might want to consider getting a reverse drill bit. As you drill, it will often loosen the bolt. Good luck! |
live free & drive |
Member ![]() ![]() Group: Members Posts: 159 Joined: 29-June 16 From: New Hampshire Member No.: 20,159 Region Association: None ![]() ![]() |
These screw extractors are made for socket head screws - they work very well:
No drilling required. http://sockitout.com/ |
rosenfe |
I’m going to try them. So they seem meant for stripped Allen head
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,545 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
I’m going to try them. So they seem meant for stripped Allen head I have used Torx bits to remove bad allen head bolts. (IMG:style_emoticons/default/agree.gif) have done the same. |
rosenfe |
I tried several but no luck.
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,513 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
I wouldn't be afraid to try a screw extractor if it wasn't a Harbor Freight or similar. Before you drill it out give it several good hammer strikes downward (probably upwards in your case). If it's recessed use a trashed bolt on top of it and hold the bolt with pliers when striking it This should upset rust and grit and free it of binding. As mentioned above, heat works well to break up the rust too. Use the largest drill bit that will set inside the stripped allen head. If you have a left hand bit then use it. Sometimes they come out when drilling CC. Keep the drill rpm low and use a cobalt or titanium bit. Keep it lubed when drilling. Don't get a side load on a cobalt or titanium bit as they are brittle. (IMG:style_emoticons/default/beerchug.gif)
bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,821 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
Get a reverse direction drill bit set.
rosenfe |
Going to try sockit out extractor. If that does not work I will drill
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,466 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
Weld a nut to the screw and turn it out. Don’t bother with the extractor. If the bit of the extractor breaks then you are in a world of pain.
Zach |
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,183 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
So far as I know, most set screws are hardened and are not drillable with conventional bits.
My vote would be either cram something in the socket or weld a nut |
rosenfe |
Used the sockitout tool today. Worked like a champ, out in 2 minutes.
rosenfe |
Now I can’t get the sockitout tool off the cone screw, but that’s minor.now I can finish dropping the engine
930cabman |
Lo-Fi Version | Time is now: 17th June 2024 - 12:51 PM |
