Frunk is locked, key won't open, My fronk is locked from inside the car. Car just won't unlock |
Ampex351 |
Jun 30 2022, 02:40 PM
Member Group: Members Posts: 104 Joined: 8-April 20 From: Roseburg, Oregon Member No.: 24,115 Region Association: Pacific Northwest |
The frunk lock got locked from the handle inside and now it won't unlock. I've tried lubing the lock and turning either way but it just won't unlock. Any ideas?
Thanks! |
mepstein |
Jun 30 2022, 02:46 PM
914-6 GT in waiting Group: Members Posts: 19,325 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
You can remove the front bumper and flip the latch through a small hole that is already in the front latch area. I’ve done it and it was easy.
Then lube everything up, including the cable housing. |
rhodyguy |
Jun 30 2022, 02:58 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,098 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
What Mark wrote. Unlock the ignition switch so you can turn the wheels for easy access to the bumper bolts. Don't reef on the cable. Squirt every fastener with penatrent. Repeatedly.
porschetub |
Jun 30 2022, 04:06 PM
Advanced Member Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
You can remove the front bumper and flip the latch through a small hole that is already in the front latch area. I’ve done it and it was easy. Then lube everything up, including the cable housing. (IMG:style_emoticons/default/agree.gif) found that little plug when I removed my bumper to do various jobs,Mark do you think this will work for the OP if the handle is locked,thinking this may stop the latch release from working ??. |
bdstone914 |
Jun 30 2022, 04:10 PM
bdstone914 Group: Members Posts: 4,542 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
You can remove the front bumper and flip the latch through a small hole that is already in the front latch area. I’ve done it and it was easy. Then lube everything up, including the cable housing. (IMG:style_emoticons/default/agree.gif) found that little plug when I removed my bumper to do various jobs,Mark do you think this will work for the OP if the handle is locked,thinking this may stop the latch release from working ??. It can still be opened by tripping the latch. |
friethmiller |
Jun 30 2022, 04:20 PM
Senior Member Group: Members Posts: 516 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region |
Agree, he will be actuating the latch directly. A locked handle isn't going to be a problem.
Ampex351 |
Jun 30 2022, 05:18 PM
You can remove the front bumper and flip the latch through a small hole that is already in the front latch area. I’ve done it and it was easy. Then lube everything up, including the cable housing. I finally got it without removing the bumper. Just kept wiggling the danged key and it popped loose and unlocked! Thanks for the tip about removing bumper just in case. |
jim_hoyland |
Jun 30 2022, 06:52 PM
Get that VIN ? Group: Members Posts: 9,328 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
914Toy showed me neat mod to avoid getting locked out. A second cable was attached to the latch adjacent to the OEM cable; the second piece is routed directly to the front fender well, a grommeted hole allows the cable end into the turn signal cavity. Lastly, add a pull ring to the cable end.
Next time the cabin pull fails, just reach under the fender and pull the that cable.., (IMG:style_emoticons/default/smile.gif) |
eric9144 |
Jul 1 2022, 10:54 AM
Advanced Member Group: Members Posts: 2,734 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
(IMG:style_emoticons/default/smash.gif)
There's an access hole behind the bumper, I video'd it last time I had to open mine so that it would hopefully help others in the future. Once you're in there it's super easy: https://www.youtube.com/watch?v=J3piAZJrKhM |
Rick986 |
Jul 1 2022, 11:19 AM
0-60 in 14 seconds! Group: Members Posts: 141 Joined: 31-August 21 From: NE Ohio Member No.: 25,869 Region Association: Upper MidWest |
What Mark wrote. Unlock the ignition switch so you can turn the wheels for easy access to the bumper bolts. Don't reef on the cable. Squirt every fastener with penatrent. Repeatedly. What is "penatrent"? What else do you guys recommend lubing these parts with??? |
mepstein |
Jul 1 2022, 12:26 PM
Almost any lubricant other than WD-40.
I would also clean out the lock tumbler and use a light lube. It gets gummed up after 50 years and fails to work properly. |
jim_hoyland |
Jul 1 2022, 12:52 PM
Another trick I picked from a Porsche mechanic: As you pull into your garage, pop open the front trunk. Close it all the way when drive off next time. Even if I drive off without completely shutting the hood, it won’t completely open. Repeated openings keeps the latch from sticking, as well as the cable from the pull handle to the latch
Lo-Fi Version | Time is now: 17th June 2024 - 03:15 AM |
