Radio install, Becker CDR220 |
theer |
Jul 3 2022, 05:01 PM
Senior Member Group: Members Posts: 677 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
I’m installing a Becker CDR220 radio.
These are from early 2000’s Boxster. With a little Bluetooth dongle you can use the CD function to use your phone. Anyway, I’ve done this before, but can’t for the life of me remember where I got the bracket to pick up the back of the radio to the mount on the firewall. Mount: Bracket I have used: Installed radio: The problem is the offset of the mount on the firewall vs the center point of the radio. I know I didn’t make that bracket. anyone know where to get one? Not sure it makes a difference, but the installed radio is in a ‘72, the new one is a ‘75. Thanks! Tom |
914Sixer |
Jul 4 2022, 06:28 AM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Try a piece of pipe strap.
Attached image(s) |
Shivers |
Jul 4 2022, 10:30 AM
Senior Member Group: Members Posts: 2,431 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Try a piece of pipe strap. He got this out before I could. Plumbers tape will work, used it before. And no one will see it. Otherwise if I was pressed for it, I'd break out a tape and make one. Cardboard template, trace on some sheet metal and use some wiss cutters and a file. Paint to suit. If you bake the tacky painted piece for three hours at 300 it will harden similar to powder coat. |
bbrock |
Jul 4 2022, 11:10 AM
I prefer to use stereo mounting strap over plumbing strap. It is heavier gauge than plumbing strap so a more solid mount, but still easy to bend.
https://www.crutchfield.com/S-4g1jdOxIjCe/p...Back-Strap.html (IMG:http://www.914world.com/bbs2/uploads_offsite/images.crutchfieldonline.com-20845-1656954610.1.jpeg) |
theer |
Jul 11 2022, 08:13 AM
Thanks- all good suggestions.
Lo-Fi Version | Time is now: 9th June 2024 - 11:48 PM |
