Is this excessive metal on the trans drain plug? |
Steve |
Jul 3 2022, 11:34 PM
914 Guru Group: Members Posts: 5,606 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
914 trans in v8 car. All gears have a slight whine, with 4th being the worst.
Runs and shifts fine. Drained oil through a strainer. No chunks, just this crap on the drain plug. Would you tear it apart or just drive it? What would the doctor do? @dr evil |
914e |
Jul 3 2022, 11:44 PM
Member Group: Members Posts: 496 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region |
914 trans in v8 car. All gears have a slight whine, with 4th being the worst. Runs and shifts fine. Drained oil through a strainer. No chunks, just this crap on the drain plug. Would you tear it apart or just drive it? What would the doctor do? @dr_evil Is the whine new or increasing? Since it is in all gears it might be a pinion bearing. |
Spoke |
Jerry Group: Members Posts: 6,986 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I'm no expert but I've never seen that much metal on the plug.
930cabman |
Jul 4 2022, 05:59 AM
Advanced Member Group: Members Posts: 3,128 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Hard to tell, but are we looking at chunks of metal or dust?
914Sixer |
Jul 4 2022, 06:24 AM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Call DR EVIL
Steve |
Jul 4 2022, 07:47 AM
914 trans in v8 car. All gears have a slight whine, with 4th being the worst. Runs and shifts fine. Drained oil through a strainer. No chunks, just this crap on the drain plug. Would you tear it apart or just drive it? What would the doctor do? @dr_evil Is the whine new or increasing? Since it is in all gears it might be a pinion bearing. 4th gear whine was always there. The whine in all the gears is new after I drag raced another muscle car off the line in second. So dumb at my age. |
Steve |
Jul 4 2022, 07:49 AM
Robarabian |
Jul 4 2022, 09:43 AM
914 A Roo Group: Members Posts: 592 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California |
MEtal is relative to time... depends when the last change was... if that was a product of metal over the course of years without an oil change, then I would not be so concerned. If it was like a 6 month oil change....yes, it would be concerning.
Dr. Evil's write up has some guidance on it as well. |
Steve |
Jul 4 2022, 05:47 PM
I put in 85-140 gear oil and now it’s quieter. It’s just a cars & coffee toy. I will run it as is until it gets worse or explodes! Lol
Thanks for the feedback. I Will look for another trans to go through versus going through this trans and have a dead car. Any used trans in the so cal area? I will also post in the want adds. |
930cabman |
Jul 4 2022, 05:52 PM
A decent used trans may run you 800 or so. Add around 1.5 at least for a rebuild. I have been a running well used trans and keep clean oil in it. Hoping to chum up with a local tranny rebuilder one of these days
Lo-Fi Version | Time is now: 1st June 2024 - 07:05 AM |
