More Black Oxide Pictures, Additional Parts Done |
914Sixer |
Jul 12 2022, 11:40 AM
914 Guru Group: Members Posts: 8,902 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Got crazy
Attached image(s) |
slivel |
Jul 12 2022, 12:09 PM
Old car....... older driver Group: Members Posts: 510 Joined: 10-July 04 From: San Diego Member No.: 2,332 Region Association: Southern California |
For us black oxide novices who want to dip our toes into this for our 914's, in your original post you said that the surface has to be very clean. What did you do? Your parts look great.
Did you do media blasting, just hand work with emery cloth, wire wheel, something else. TIA. |
914Sixer |
Jul 12 2022, 01:46 PM
Used wire wheel on most, then did a vinegar soaking. Checked everything from there. Some required a second round of cleaning.
nathanxnathan |
Jul 12 2022, 06:25 PM
Member Group: Members Posts: 291 Joined: 16-February 18 From: Laguna Beach, CA Member No.: 21,899 Region Association: Southern California |
I'd like to see Caswell's zinc black chromate kit in action.
Literati914 |
Jul 12 2022, 08:19 PM
Senior Member Group: Members Posts: 1,475 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
would the black oxide be a no-no on bearing surfaces such as you have at the axle assemblies?
Costa05 |
Jul 12 2022, 09:10 PM
Member Group: Members Posts: 320 Joined: 27-October 16 From: Phoenix, Arizona Member No.: 20,535 Region Association: Southwest Region |
I did the same on almost all of my hardware. Really wanted black so gave it go. Turned out great. So far at least.
Attached image(s) |
friethmiller |
Jul 13 2022, 10:11 AM
Member Group: Members Posts: 499 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region |
If anyone is curious, I photo-documented my efforts in Zinc-Nickel and Zinc plating for my 914 on my smugmug site. Just a dozen or so images but each one has a few details of the action. I went "high-class" with my paper plates and scotch tape. Most of the bolts and washers were purchased from Belmetric but I did re-plate the door bolts. Another thing to keep in mind your drying rack. I recommend you take time to have a better setup than I did. My fan blew some of the small parts into each other, which messed up the 'still delicate' chromate.
https://fredriethmiller.smugmug.com/1974-Po...Apr-Jun-2020/59 |
friethmiller |
Jul 13 2022, 10:33 AM
Couple images of the results:
nathanxnathan |
Jul 13 2022, 02:21 PM
If anyone is curious, I photo-documented my efforts in Zinc-Nickel and Zinc plating for my 914 on my smugmug site. Just a dozen or so images but each one has a few details of the action. I went "high-class" with my paper plates and scotch tape. Most of the bolts and washers were purchased from Belmetric but I did re-plate the door bolts. Another thing to keep in mind your drying rack. I recommend you take time to have a better setup than I did. My fan blew some of the small parts into each other, which messed up the 'still delicate' chromate. https://fredriethmiller.smugmug.com/1974-Po...Apr-Jun-2020/59 Nice,cool to see. (IMG:style_emoticons/default/beerchug.gif) |
ValcoOscar |
Jul 13 2022, 02:44 PM
Garage Life Group: Members Posts: 2,388 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California |
If anyone is curious, I photo-documented my efforts in Zinc-Nickel and Zinc plating for my 914 on my smugmug site. Just a dozen or so images but each one has a few details of the action. I went "high-class" with my paper plates and scotch tape. Most of the bolts and washers were purchased from Belmetric but I did re-plate the door bolts. Another thing to keep in mind your drying rack. I recommend you take time to have a better setup than I did. My fan blew some of the small parts into each other, which messed up the 'still delicate' chromate. https://fredriethmiller.smugmug.com/1974-Po...Apr-Jun-2020/59 _____________________________ Simply E X C E L L E N T (IMG:style_emoticons/default/beerchug.gif) D'man of the day (IMG:style_emoticons/default/pray.gif) O |
Vysoc |
Jul 13 2022, 03:28 PM
Vysoc Group: Members Posts: 586 Joined: 27-August 09 From: Young Harris, Georgia Member No.: 10,737 Region Association: South East States |
Lo-Fi Version | Time is now: 6th June 2024 - 03:06 PM |
