Clutch Pedal Travel, What's typical? |
windforfun |
Jul 13 2022, 03:26 PM
Senior Member Group: Members Posts: 1,837 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Should a properly adjusted clutch cable result in a pedal travel that's almost all the way to the floor for clutch action? With the pedal board & carpeting there's about 1" of extra pedal travel after the clutch disengages. Thanks.
rjames |
Jul 13 2022, 03:48 PM
I'm made of metal Group: Members Posts: 3,955 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
windforfun |
Jul 13 2022, 04:18 PM
Thanks for the help.
I just tweaked the cable length by about + 1/2". All seems to be fine. The fork is about 1/4" from the forward casing & the pedal kicks in at about 2" or less. There's no clutch slip under load. Does this make sense?: Cable too loose - late clutch disengagement or pedal to the floor Cable too tight - early clutch disengagement &/or slippage under load Cheers. (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) "If the clutch disengages too early then it is too tight, too late then it is too loose." Captain Obvious here. |
Lo-Fi Version | Time is now: 8th June 2024 - 07:56 PM |
