Rotisserie ? |
Rotisserie ? |
914GTSTI |
Jul 19 2022, 08:49 PM
Member Group: Members Posts: 270 Joined: 16-September 07 From: Glendale AZ Member No.: 8,123 Region Association: None |
Is anybody using the Restoration Design Rotisserie ?
How does it work for you ? Thanks |
VaccaRabite |
Jul 20 2022, 12:47 PM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Build your own. Its cheaper, and if your car needs enough work that you want a rotisserie then you either know how to weld already or need practice welding the rot together if you don't.
All of the tools that you need to build the rotisserie you will need fixing the rust in your car. Zach |
friethmiller |
Jul 20 2022, 12:56 PM
Member Group: Members Posts: 494 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region |
I was just like you 4 years ago and the old timers gave me the same advice. Build your own. So, I built the RD rotisserie and it worked great! Would highly recommend going this route. Cost was 1/4 of what a store-bought one would have cost and was a lot stronger. Gave me a refresher in welding, too. Beware the transmission mounts on the blueprints are 180 degrees out. I didn't catch this till I went to mount the rear hoop - had to cut and reweld them on the correct way. Just look at your transmission mount and you'll see what I mean.
On a side note. I actually sold mine after I was finished with it to a guy locally. Damn if I didn't just buy another 914! Going to have to build the same rotisserie again! Looking forward to it, actually. Good Luck!! |
infraredcalvin |
Jul 20 2022, 01:24 PM
Distracted Member Group: Members Posts: 1,523 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
I built this one, some people start with a pair of hf engine stands then modify to suit needs.
https://blueskymotorsports.com/Porsche%2091...0Rotisserie.pdf |
friethmiller |
Jul 20 2022, 02:14 PM
I recommend bracing the car before mounting it on a rotisserie - and certainly before you start welding on it. Here's a picture of mine a while back when I was installing the floors. Look at the bracing I have in place. It's easy to do and prevents anything from moving/twisting once you've set/verified your dimensions.
Andyrew |
Jul 20 2022, 02:40 PM
Miss post.
914GTSTI |
Jul 20 2022, 03:59 PM
Thanks all.
It looks like it would make things easer. Yes, I will build my own. And yes on the bracing. Have the plans for the "Restoration Design". Was thinking about the 1 1/4" tubing. What wall thickness ? 1/8" ? Also been thinking about adding a portable 2 post car lift. With that and the rotisserie I should be able to do most of it by myself . Now I just need my VersaTube building. Its a 17' x 25' x 10'. Cement is in . Power is run. |
gord |
Jul 20 2022, 04:46 PM
Member Group: Members Posts: 76 Joined: 30-May 20 From: Toronto, Canada Member No.: 24,334 Region Association: Canada |
@friethmiller — this shot showing the suspension mount at the front is illuminating. Any chance you can post a pic showing how it mounts at the rear?
mepstein |
Jul 20 2022, 05:01 PM
914-6 GT in waiting Group: Members Posts: 19,305 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I wouldn’t put a 914 that needs rust repair on a rotisserie.
Even bracing the doors, it’s easy to bend or twist the chassis. |
friethmiller |
Jul 20 2022, 08:22 PM
@friethmiller — this shot showing the suspension mount at the front is illuminating. Any chance you can post a pic showing how it mounts at the rear? Ok, here's some better pics just for you (front and rear). Couldn't find the correct length bolts so I used a bunch of washers on the front mount - ugly, I know. On the rear hoop, you can see how I had to cut and reweld the legs that go to the transmission mounts. I recommend painting it. This thing will rust if you don't and it gets all over your hands and in your primer. Just use anything that will cover the bare metal. |
friethmiller |
Jul 21 2022, 03:44 AM
I wouldn’t put a 914 that needs rust repair on a rotisserie. Even bracing the doors, it’s easy to bend or twist the chassis. I hear you, @mepstein . That’s why I braced on the diagonal like this. The reason you mount the car on a rotisserie is to repair the rust damage. With that said, I only went 90 degrees for the floor pan replacement. The rest of the time was spent flat or at a very handy 45 degrees. |
nathanxnathan |
Aug 1 2022, 10:59 AM
Member Group: Members Posts: 284 Joined: 16-February 18 From: Laguna Beach, CA Member No.: 21,899 Region Association: Southern California |
I'm thinking about building a rotisserie in this fashion, and I have a few questions maybe someone has some insight on.
Firstly, it seems to me that the outer suspension consoles would be better than the transmission mounts for mounting the rear? Doing so would mean you not need eight ~9ft pieces of steel (requiring purchase of eight 10 ft pieces to be cut off). I haven't measured what you'd need exactly, but at most eight footers. Supporting at the suspension mounts also would seem to strain the diagonal parts of the longs less, and cause less sag in the body? The other question I have is about use of the cross support for the steering/A arms as part of the rotisserie. I don't really have a spare piece and it seems like it would be easier to use a stout beam like a .25" wall 2 x 2 or similar to bolt to the same locations? Is there something I'm not considering why using/sacrificing the stock piece is preferable? |
friethmiller |
Aug 1 2022, 11:30 AM
I'm thinking about building a rotisserie in this fashion, and I have a few questions maybe someone has some insight on. Firstly, it seems to me that the outer suspension consoles would be better than the transmission mounts for mounting the rear? Doing so would mean you not need eight ~9ft pieces of steel (requiring purchase of eight 10 ft pieces to be cut off). I haven't measured what you'd need exactly, but at most eight footers. Supporting at the suspension mounts also would seem to strain the diagonal parts of the longs less, and cause less sag in the body? The other question I have is about use of the cross support for the steering/A arms as part of the rotisserie. I don't really have a spare piece and it seems like it would be easier to use a stout beam like a .25" wall 2 x 2 or similar to bolt to the same locations? Is there something I'm not considering why using/sacrificing the stock piece is preferable? Having used this design, I would agree that the outer suspension points would be better. The only drawback would be in the repair of said point(s). Perhaps an alternate location could be used during this repair - be it temporary. My car was so bad, I ended up pulling both outers and replacing one of the inner consoles during my restoration. I used a jig for this to help with the inner but not the outers. I think you might be on to something here. Hope you have some CADD skills. (IMG:style_emoticons/default/biggrin.gif) For the front suspension bar, you don't have to use it. However, to keep the car level with this design, you would need to fabricate something of similar dimensions. I like this idea as well. Access to your "troubled spots" and for painting should be considered as well. |
808 WRX |
Aug 1 2022, 02:01 PM
Member Group: Members Posts: 59 Joined: 4-June 20 From: San Jose, CA Member No.: 24,349 Region Association: Northern California |
Hi @nathanxnathan
This is pretty much what I have in mind, except I am going to build a body cart and then bolt the hoops to the body cart. The body cart will attach to the body at the suspension consoles in the back and the steering/A-arm cross support in the front. I bought the metal, just need to take the suspension off and get to work (IMG:style_emoticons/default/welder.gif) |
nathanxnathan |
Sep 24 2022, 11:52 PM
So I finished the rotisserie. I now see how using the beam for the suspension saves a lot of trouble. Making the plates for the front mount was the hardest part for me.
I'm a bit disappointed though. It's very difficult to change the angle of the car and it doesn't balance on the diagonals by itself. By myself I can lift the car to the diagonal position but I'm unable to get it to the sideways position on my own. (IMG:http://www.914world.com/bbs2/uploads/post-21899-1663035616_thumb.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-21899-1663035638_thumb.jpg) I have the rear suspension still on so maybe if I had that off? — it has the trailing arms, shocks, rear calipers and brake discs so that is quite a bit of weight. I did the dimensions and angles exactly as per the RD plan. I used larger casters so I offest the mounting bar up. Looking at my plan compared to the RD plan, it looks like mine sits lower, but I don't think it affects lifting it from the diagonal to the side or how it balances on the diagonal. How I built mine RD Plans are in this thread http://www.914world.com/bbs2/index.php?sho...209540&st=0 I think if the car was higher up in the hoops it might be easier. All the weight is at the bottom. I had some help from a friend to get it on its side, but I'm racking my brain on how I'm going to get it back down. (IMG:style_emoticons/default/huh.gif) |
TonyH |
Sep 25 2022, 07:24 AM
Member Group: Members Posts: 50 Joined: 30-January 22 From: Normandy, France Member No.: 26,296 Region Association: France |
So I finished the rotisserie. I now see how using the beam for the suspension saves a lot of trouble. Making the plates for the front mount was the hardest part for me. I'm a bit disappointed though. It's very difficult to change the angle of the car and it doesn't balance on the diagonals by itself. By myself I can lift the car to the diagonal position but I'm unable to get it to the sideways position on my own. (IMG:http://www.914world.com/bbs2/uploads/post-21899-1663035616_thumb.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-21899-1663035638_thumb.jpg) I have the rear suspension still on so maybe if I had that off? — it has the trailing arms, shocks, rear calipers and brake discs so that is quite a bit of weight. I did the dimensions and angles exactly as per the RD plan. I used larger casters so I offest the mounting bar up. Looking at my plan compared to the RD plan, it looks like mine sits lower, but I don't think it affects lifting it from the diagonal to the side or how it balances on the diagonal. How I built mine RD Plans are in this thread http://www.914world.com/bbs2/index.php?sho...209540&st=0 I think if the car was higher up in the hoops it might be easier. All the weight is at the bottom. I had some help from a friend to get it on its side, but I'm racking my brain on how I'm going to get it back down. (IMG:style_emoticons/default/huh.gif) I have made a couple of different systems for safely rolling a car over the years. A simple couple of large square steel box section circles with with mounting points welded on. OK for things like a small pre war Fiat Topolino saloon. For larger saloons and small commercials I made a rotisserie that worked really well. Mounted front and rear of the vehicle. But they were always for closed cars or vans. As soon as you try to mount a possibly rusty open car like a 914 it will bend like it is made out of wet cardboard. Nothing will ever fit afterwards. I suggest the RD system is the only safe way to go. I will dig out some pictures of the other types when I get a minute. |
Front yard mechanic |
Sep 25 2022, 07:41 AM
Senior Member Group: Members Posts: 1,169 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
I built the same rotisserie but the car is up higher , almost to the top and with out the suspension it’s easy to roll alone. I also welded out riggers bolted to the motor mounts & to the door braces to keep the car from wiggling. I try to add a picture (IMG:style_emoticons/default/beer.gif)
stoneman30hotmail |
Sep 26 2022, 02:39 PM
Member Group: Members Posts: 80 Joined: 10-September 22 From: Greensboro, NC Member No.: 26,834 Region Association: South East States |
I thought I saw someone say this octagon was like $300 in steel. But I'm pricing this out and getting more like $800. Am I missing something? I'm starting to wonder if the engine stand version might be more efficient. This is really just for replacing the floor, right?
I was tempted to put the octagon version in a CAD to get miter angles as well as try to get the car up near the CG if that's not where it is. I'm guessing it's near the bumper since those with the engine stand version say it turns nicely there. Though maybe the issue is body only vs suspension etc. |
nathanxnathan |
Sep 26 2022, 04:55 PM
I thought I saw someone say this octagon was like $300 in steel. But I'm pricing this out and getting more like $800. Am I missing something? I'm starting to wonder if the engine stand version might be more efficient. This is really just for replacing the floor, right? I was tempted to put the octagon version in a CAD to get miter angles as well as try to get the car up near the CG if that's not where it is. I'm guessing it's near the bumper since those with the engine stand version say it turns nicely there. Though maybe the issue is body only vs suspension etc. I went the route of the octisserie because of its length. The "pro" style rotisserie I designed required an extra 40 inches more than the length of the car. I used .125" wall 1.25" square, and had to use 13 10 footers. I had metal for the caster plates, crossbeam mounting plates, plate for the mounts, as well as for the reinforcements just laying around. I spent about $500. I've been removing the undercoat — in preparation for some work on the floor, but I also have improved access to some aspects of the front clip which I'm working on. I've been tig welding everything and it's rough to squat and use the pedal so the sideways position has been a big help. My angles are the same as the RD plan and I calculated the angles to get them to fit. Here's an Illustrator editable 1:1 scale pdf that I did. http://www.914world.com/bbs2/index.php?act...t&id=851199 I'd say the CG is slightly above the bumper as the engine stand type rotisseries, the yoke is centered on the bumper, but they adjust to pivot from further up. Around the to pad or just above is where the CG is. |
930cabman |
Sep 27 2022, 04:49 AM
Advanced Member Group: Members Posts: 3,128 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
I would welcome renting one if anyone in the NE has the RD style. Sure, I could fab one up, but it's possible another member has one collecting dust and could use some extra $$.
Lo-Fi Version | Time is now: 1st June 2024 - 02:32 AM |
