Repairing a Repair ? |
914GTSTI |
Jul 28 2022, 08:03 PM
Member Group: Members Posts: 270 Joined: 16-September 07 From: Glendale AZ Member No.: 8,123 Region Association: None |
Have a drivers front repair that is a lap repair.
What would be the best way ? Pull it all out or make a 1/32" cut between the two parts ? |
914GTSTI |
Jul 28 2022, 11:17 PM
Ok.
Thanks |
nathanxnathan |
Jul 28 2022, 11:52 PM
Member Group: Members Posts: 290 Joined: 16-February 18 From: Laguna Beach, CA Member No.: 21,899 Region Association: Southern California |
Isn't that always how it is, someone makes a "repair" and it messes up everything around it. There are rare cases, and I'm always surprised when I find some small evidence that a repair has been done and properly. In this case it's inevitable that dirt and moisture will gather between the layers there.
I wonder what it's doing there. What does the top look like? |
Superhawk996 |
Jul 29 2022, 03:31 AM
914 Guru Group: Members Posts: 5,884 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Front yard mechanic |
Jul 29 2022, 05:13 AM
Senior Member Group: Members Posts: 1,170 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
I think I’m looking at the front? Passenger side? What does the top side look like. Is the whole clip done or just the corner. It can be saved (IMG:style_emoticons/default/welder.gif)
SirAndy |
Jul 29 2022, 10:43 AM
Resident German Group: Admin Posts: 41,671 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
So many questions ...
(IMG:style_emoticons/default/unsure.gif) |
Cairo94507 |
Jul 29 2022, 10:49 AM
Michael Group: Members Posts: 9,815 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
The last thing anyone wants is to spend lots of time and money getting a car ready for paint and then after color, a couple years go by and poor prep rears its ugly head. (IMG:style_emoticons/default/beerchug.gif)
dr914@autoatlanta.com |
Jul 29 2022, 11:00 AM
914 Guru Group: Members Posts: 7,888 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
totally agree
Have a drivers front repair that is a lap repair. What would be the best way ? The proper way is pull it all out, clean any corrosion that is inevitably between the panels and repair properly with new metal and butt weld. |
Puebloswatcop |
Jul 29 2022, 07:46 PM
Senior Member Group: Members Posts: 1,389 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region |
Wow, I'm not sure I'd even call that a repair, looks more like a brush with suicide if what I am seeing is where the shock mounts. I would probably try to access an entire inner fender so you can cut it back to good metal and the butt weld it. If it is what I am seeing , just make sure you make very precise measurements, so you can set the camber after the repair is done.
bkrantz |
Jul 29 2022, 09:40 PM
914 Guru Group: Members Posts: 7,794 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Just a guess based on one photo, but to do it right might mean detaching the outer fender.
Lo-Fi Version | Time is now: 4th June 2024 - 06:19 AM |
