Wiper motor repair, Removing mechanism |
Ishley |
Aug 10 2022, 06:31 AM
Member Group: Members Posts: 106 Joined: 4-October 21 From: Clarendon Hills Il Member No.: 25,957 Region Association: Upper MidWest |
When I got my 72, 1.7 the fan and the wipers did not work. I knew the fan was likely full of debris as the grill was off on top of the unit. I got the blower out and cleaned everything out and tested… all is good.
Now I’m trying to remove the wiper mechanism as I want to test the motor and checkout/cleanup the mechanism. I can’t get it out. I know there is a back nut to remove under the dash. I think I can feel it when I reach way up under the dash. I’ve searched the forums and can’t find a procedure. I think I saw a post once to remove the gauge cluster to get to the nut. Is this the best way to get to it? Can it be done without taking the gauges out? Thanks in advance for help from those who have done this. |
Ishley |
Aug 10 2022, 07:18 AM
Figured it out. Swivel socket on a long reach behind the ash try. Screwed around for hours yesterday. Once I went behind the ashtray I had it in 5 min. Oh well. Live and learn.
nditiz1 |
Senior Member Group: Members Posts: 1,191 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
Super easy to see if you remove the speedo gauge. Even more room if you drop the whole cluster fwd. Remove steering wheel to help with that as well. If you want to short cut it, you can do it blindly, but you won't be able to easily put it back without taking out the gauge so it is advisable to just do it right the first time.
Edit: didn't know about the ash tray trick. Maybe I'll use that next time. |
Ishley |
Aug 10 2022, 09:11 AM
Ashtray approach works but barely. It will be tough to get nut back on.
Tested and the system works. Must be a switch or wiring issue that I will track down before I put it all back together. |
Lo-Fi Version | Time is now: 9th June 2024 - 06:52 PM |
