Flat tow set up questions, i have a few questions for those that may have done this before with a 914 |
DRPHIL914 |
Aug 17 2022, 09:36 AM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I know there are a few out there that have done the flat tow. i have my tow bar bracket bolted into place and the OEM valance removed. a common issue is the amount of drop required for the tow hitch ball. My Lincoln Navigator does have tow package and sits higher than expected, so it’s a lot of angle there, even with a 5” drop hitch. i have ordered a 10” drop hitch and that should be better . i took a few pictures with the yolk attached to the truck, and with it on jack stands set at what will be the same height of the bar on the car , which is 8” from the pavement.
I believe with the 10” drop, the ball will be about 4” higher than parallel, now it would be about 10” and that’s too steep an angle. one thought was couldn’t you mount tow brackets in behind the fog light grills? that would raise it 6-8” ans make it perfectly leave with my current drop hitch, BUT how much reinforcement would be required? has anyone done this? Phil Attached thumbnail(s) |
914werke |
Aug 17 2022, 09:51 AM
"I got blisters on me fingers" Group: Members Posts: 10,145 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Its been done but the only reinforcing steel for the crosswall (the metal behind the grills) is the vertical wheel well supports, which I believe were designed for push or crumple protection not pull, plus it would require some welding or drilling vs just bolt on
Lo-Fi Version | Time is now: 11th June 2024 - 03:14 AM |
