crank pulley removal |
914-Kazoo |
Aug 19 2022, 09:26 AM
Newbie Group: Members Posts: 45 Joined: 19-August 20 From: Kalamazoo, MI Member No.: 24,609 Region Association: Upper MidWest |
Trying to remove the pulley fitting from the crankshaft. Past 4 days I've used blaster and heat but no luck.. Ive added the bolts to exert some force but reluctant to tighter to much for fear of damaging fitting or crank. Can someone offer advice on how to remove? Thanks for the help.
914_74_crank_pulley.pdf ( 100.68k )
brant |
Aug 19 2022, 09:31 AM
914 Wizard Group: Members Posts: 11,638 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
its been a while for me....
but I "think" that one is a taper fit and requires lots and lots of heat.... plus possibly a new seal afterwards. A three armed puller may help also Brant |
914werke |
Aug 19 2022, 11:21 AM
"I got blisters on me fingers" Group: Members Posts: 10,124 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
there is a special tool you are missing. Nothing more than a piece of sheet steel shaped like a C
Once slid behind the hub use those 3 bolts & it'll pop right off. DONT use the case in it place ~ |
mgphoto |
Aug 19 2022, 11:59 AM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Take a flat piece of steel, 1/8 inch thick 2 inches wide 4 inches long.
Screw bolts long enough to contact the steel as you place it against the case, screw down on the plate and move it to the other screw holes and do the same, it will push off eventually. |
914Sixer |
Aug 19 2022, 12:06 PM
914 Guru Group: Members Posts: 8,902 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Factory tool Looks like this
Attached thumbnail(s) |
930cabman |
Aug 19 2022, 01:01 PM
Advanced Member Group: Members Posts: 3,144 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Yes, use a puller for sure as it is a tapered fit. I use a smallish steering wheel puller.
DO NOT pry against the case |
914-Kazoo |
Aug 22 2022, 06:03 AM
Its off !!! Thanks guys for all the suggestions
Dave_Darling |
Aug 22 2022, 05:33 PM
Special tool not required--just get some fender washers or other moderately thick pieces of sheet metal to spread the load across the face of the crankcase. Thread the fan bolts into the hub far enough to trap the washers between the bolt ends and the case. Then turn them all about a half-turn at a time, one after the other. It'll pop off easily.
--DD |
930cabman |
Aug 22 2022, 06:08 PM
Special tool not required--just get some fender washers or other moderately thick pieces of sheet metal to spread the load across the face of the crankcase. Thread the fan bolts into the hub far enough to trap the washers between the bolt ends and the case. Then turn them all about a half-turn at a time, one after the other. It'll pop off easily. --DD Great tip Dave |
iankarr |
Aug 22 2022, 09:12 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,480 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Congrats on getting it off! Bet it startled ya when it popped free (IMG:style_emoticons/default/smile.gif) I put a white sheet on the floor so I can find the woodruff key if it pops out.
914-Kazoo |
Aug 23 2022, 06:48 AM
Ian, I could have used that warning couple of days ago, yes it did catch me off guard when that baby popped off.
Thanks again for everyones help. |
Lo-Fi Version | Time is now: 7th June 2024 - 03:10 AM |
