Removing TPS - does the throttle body have to come off?, or can i just pull it off the shaft? |
FlacaProductions |
Aug 23 2022, 07:09 PM
Senior Member Group: Members Posts: 1,615 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
I have a little stumble/hesitation right around 3k cruising. All else is good. Unplugged the TPS and the stumble goes away. It's pretty clear.
Looking to do a quick clean until i have time and can get a replacement board here. Can I just take the connector and two mounting screws off the side of the TPS and pull it off the shaft without having to remove the air cleaner housing and throttle body, etc? |
914werke |
Aug 23 2022, 07:57 PM
"I got blisters on me fingers" Group: Members Posts: 10,124 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
No. unplug the harness connector, two small (M4) screws on either side & pull out, off of the D-shaft.
GregAmy |
Aug 23 2022, 08:02 PM
Advanced Member Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
^^^Ditto, but...if you're going through all that trouble, just buy a new TPS board:
http://www.914world.com/bbs2/index.php?showtopic=129025 https://914rubber.com/2-0-l-throttle-position-sensor-board Note it needs to be adjusted after reinstall: https://www.pelicanparts.com/techarticles/9...alibrate_20.jpg EDIT! I see yours is a 1.7. See this link for purchase: https://914rubber.com/search/?q=tps EDIT2! ...and I now see current is 2L and former was 1.7.... |
FlacaProductions |
Aug 23 2022, 08:28 PM
Thanks for this Rich @914werke and @GregAmy .
I'm ordering a board (and it IS a 74 2.0) but just confirming that I can do as Rich said and just two screws and the connector. NO throttle body, etc. needs to come off - and yes on the adjustment after install. Perfect. Thanks for making sure I had it right in my head. |
Lockwodo |
Aug 23 2022, 09:18 PM
Member Group: Members Posts: 201 Joined: 23-December 21 From: Santa Cruz, Californnia Member No.: 26,193 Region Association: Northern California |
I have a little stumble/hesitation right around 3k cruising. All else is good. Unplugged the TPS and the stumble goes away. It's pretty clear. Looking to do a quick clean until i have time and can get a replacement board here. Can I just take the connector and two mounting screws off the side of the TPS and pull it off the shaft without having to remove the air cleaner housing and throttle body, etc? In my experience, best to pull the throttle body so you can have it on a workbench when replacing the TPS and calibrating it. Super easy to do with throttle body off the car. |
rjames |
Aug 23 2022, 11:55 PM
I'm made of metal Group: Members Posts: 3,954 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Easy to remove the TPS without removing the TB and easy to calibrate in the car. If you do remove the TB, have a new gasket on hand.
JamesM |
Aug 24 2022, 12:24 AM
Senior Member Group: Members Posts: 1,915 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
On a 2.0 its no problem. On a 1.7 it might be a tricky endeavor to try and get it off without pulling the throttle body.
FlacaProductions |
Aug 24 2022, 06:59 AM
I think I'll try it without pulling the TB first - messes with less, overall.
Lockwodo |
Aug 24 2022, 10:12 AM
I think I'll try it without pulling the TB first - messes with less, overall. A pair of ohm meter test leads with micro alligator clips will help for the calibration step. The TPS pins will be facing downwards but with a mirror you'll be able to connect the leads to the right pins. |
FlacaProductions |
Aug 24 2022, 11:44 AM
Good tip on the clips - got those - good to go.
Highland |
Aug 25 2022, 07:59 AM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
Good tip on the clips - got those - good to go. If you're in an experimenting mood and haven't ordered a new board yet, I'd be glad to send you this one for free. I had these made just for fun but haven't had an application to test them. Just my opinion, but in my experience removing and re-installing the TB is less work than trying to calibrate the TPS in an awkward position. |
FlacaProductions |
Aug 25 2022, 08:07 AM
Thanks @Highland - I'm probably not the right guy to burn one of these on as i'm only here with the 914 for another couple of days and it's not worth the fedex costs. I'm going to pull the TPS before I head back to LA and do the board swap there - then it'll be a few weeks before i'm back to do the re-install.
That said - if you want to send me one, I'd happily be a guinea pig but won't be able to report right back! |
Highland |
Aug 25 2022, 08:30 AM
Thanks @Highland - I'm probably not the right guy to burn one of these on as i'm only here with the 914 for another couple of days and it's not worth the fedex costs. I'm going to pull the TPS before I head back to LA and do the board swap there - then it'll be a few weeks before i'm back to do the re-install. That said - if you want to send me one, I'd happily be a guinea pig but won't be able to report right back! @FlacaProductions Sure, I'll send you one. I'm in no rush to get feedback. Just PM me your address. I got 20 of them for $4 when I was ordering PCB's for another project. (IMG:style_emoticons/default/biggrin.gif) |
FlacaProductions |
Aug 25 2022, 09:33 AM
914world karma strikes again...PM sent.
Lo-Fi Version | Time is now: 6th June 2024 - 10:58 PM |
