I have a little stumble/hesitation right around 3k cruising. All else is good. Unplugged the TPS and the stumble goes away. It's pretty clear.
Looking to do a quick clean until i have time and can get a replacement board here. Can I just take the connector and two mounting screws off the side of the TPS and pull it off the shaft without having to remove the air cleaner housing and throttle body, etc?
