Removing TPS - does the throttle body have to come off?, or can i just pull it off the shaft? |
FlacaProductions |
Aug 23 2022, 07:09 PM
Senior Member Group: Members Posts: 1,584 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
I have a little stumble/hesitation right around 3k cruising. All else is good. Unplugged the TPS and the stumble goes away. It's pretty clear.
Looking to do a quick clean until i have time and can get a replacement board here. Can I just take the connector and two mounting screws off the side of the TPS and pull it off the shaft without having to remove the air cleaner housing and throttle body, etc? |
Lo-Fi Version | Time is now: 17th May 2024 - 04:27 AM |
