Voltage Drops and Dim Dash Boards and Bouncy headlamp, Sure I can fix this, but, how did you fix it? |
ctc911ctc |
Aug 29 2022, 11:51 AM
Senior Member Group: Members Posts: 893 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
1974, 2L, 24K
Took the car out last night a few issues. (IMG:style_emoticons/default/smile.gif) 1. Dimm Dashboard - seems about 1/2 brightness behind the dash and gauges (IMG:style_emoticons/default/driving-girl.gif) 2. Left headlamp bouncy - seems that the whole unit is bouncy - I may be missing the support bolt? (that weird-looking bolt in the headlamp well, does the lamp rest on it?) (IMG:style_emoticons/default/shades.gif) Oh, yes the rheostat is full bright (headlamp pull switch rotation) (IMG:style_emoticons/default/driving.gif) Any pointers before I get the VOM? (IMG:style_emoticons/default/confused24.gif) |
TheCabinetmaker |
Aug 30 2022, 09:01 AM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Faulty grounds. Clean them up!
ClayPerrine |
Aug 30 2022, 12:15 PM
Life's been good to me so far..... Group: Admin Posts: 15,498 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Bouncy headlights are normally do to a missing or misadjusted stop bolt.
The stop bolt is mounted to the back of the headlight box, and when the headlight comes up, it contacts the head of the stop bolt. Adjust the headlights so they fit right, then turn the lights on and adjust the stop bolt to just barely touch the bracket on the headlight frame. (IMG:http://www.914world.com/bbs2/uploads_offsite/914world.com-1143-1661883355.1.jpg) Good luck! Clay |
Jamie |
Aug 30 2022, 02:26 PM
Senior Member Group: Members Posts: 1,033 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States |
Bouncy headlights are normally do to a missing or misadjusted stop bolt. The stop bolt is mounted to the back of the headlight box, and when the headlight comes up, it contacts the head of the stop bolt. Adjust the headlights so they fit right, then turn the lights on and adjust the stop bolt to just barely touch the bracket on the headlight frame. (IMG:http://www.914world.com/bbs2/uploads_offsite/914world.com-1143-1661883355.1.jpg) Good luck! Clay Hey Clay, I see rare original Delphi Green paint under there! Must be a 73 or 74 model year. |
ctc911ctc |
Aug 31 2022, 03:07 PM
Clay - THANK YOU - (IMG:style_emoticons/default/beerchug.gif)
I will buy new bolts - Auto Atlanta seems to have a few in stock - do not see them anywhere else, CTC Bouncy headlights are normally do to a missing or misadjusted stop bolt. The stop bolt is mounted to the back of the headlight box, and when the headlight comes up, it contacts the head of the stop bolt. Adjust the headlights so they fit right, then turn the lights on and adjust the stop bolt to just barely touch the bracket on the headlight frame. (IMG:http://www.914world.com/bbs2/uploads_offsite/914world.com-1143-1661883355.1.jpg) Good luck! Clay |
ClayPerrine |
Aug 31 2022, 03:13 PM
Bouncy headlights are normally do to a missing or misadjusted stop bolt. The stop bolt is mounted to the back of the headlight box, and when the headlight comes up, it contacts the head of the stop bolt. Adjust the headlights so they fit right, then turn the lights on and adjust the stop bolt to just barely touch the bracket on the headlight frame. (IMG:http://www.914world.com/bbs2/uploads_offsite/914world.com-1143-1661883355.1.jpg) Good luck! Clay Hey Clay, I see rare original Delphi Green paint under there! Must be a 73 or 74 model year. Not my car, just a picture I found here on World with the proper info. Clay |
Lo-Fi Version | Time is now: 1st June 2024 - 04:30 AM |
