door panel backing/plastic, plastic behind door panel |
Medtner3 |
Aug 31 2022, 05:38 PM
Member Group: Members Posts: 180 Joined: 7-July 20 From: Cedar Park Member No.: 24,467 Region Association: None |
Any suggestions on what to use to replace the plastic behind the door panels
Thank you |
Geezer914 |
Aug 31 2022, 05:45 PM
Geezer914 Group: Members Posts: 1,441 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Just buy some heavy plastic sheeting at Lowes or Home Depot. Trim to fit the door and secure it with double stick tape.
TheCabinetmaker |
Aug 31 2022, 08:47 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I think 914 rubber has those
ClayPerrine |
Sep 1 2022, 08:44 AM
Life's been good to me so far..... Group: Admin Posts: 15,512 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
914 Rubber door vapor barrier kit. I put a set in the six. They fit perfectly. Clay |
bbrock |
Sep 1 2022, 12:21 PM
(IMG:style_emoticons/default/agree.gif) 914 Rubber door vapor barrier kit. I put a set in the six. They fit perfectly. Clay Do they include the little plastic flap at the bottom that tucks inside the door to redirect condensate running down the plastic back into the door so it drains out the drain holes? |
dr914@autoatlanta.com |
Sep 1 2022, 12:50 PM
914 Guru Group: Members Posts: 7,893 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
ours do
Medtner3 |
Sep 1 2022, 03:54 PM
(IMG:style_emoticons/default/agree.gif) 914 Rubber door vapor barrier kit. I put a set in the six. They fit perfectly. Clay Do they include the little plastic flap at the bottom that tucks inside the door to redirect condensate running down the plastic back into the door so it drains out the drain holes? I think best I take the Auto Atlanta one this time lol Thanks George Wes |
Mikey914 |
Sep 2 2022, 11:51 AM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I made a replication of the 75 barriers I had. Anyone have pics? It should be simple, just haven't see a "flap" before.
If you have this much water inside your door, it may explain the rust in the bottom channel. My understanding was it was like a house. Cold outside warm and humid inside (if you actually drive it in the winter). The vapor barrier would keep the warm air from being cooled by the metal on the door. |
bbrock |
Sep 2 2022, 12:22 PM
I made a replication of the 75 barriers I had. Anyone have pics? It should be simple, just haven't see a "flap" before. If you have this much water inside your door, it may explain the rust in the bottom channel. My understanding was it was like a house. Cold outside warm and humid inside (if you actually drive it in the winter). The vapor barrier would keep the warm air from being cooled by the metal on the door. I'm not saying the flap is important, I just know it was on all the barriers I've seen (which isn't that many) so I replicated it when I did mine. But to your point. I think it is more about controlling condensate/dew that forms inside these metal cavities when the car sits at dew point in a humid environment - plus any water that leaks past the window squeegees in the rain. Given that the other side of the vapor barrier is against fiber board prone to water damage, I can see why the Germans got picky about this. But if the car has your plastic door cards, it would make no difference since they won't be water damaged. |
Olympic 914 |
Sep 2 2022, 05:53 PM
Group: Members Posts: 1,675 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Lo-Fi Version | Time is now: 6th June 2024 - 11:17 PM |
