OT 911 Strut identification |
Freezin 914 |
Sep 11 2022, 01:30 PM
Senior Member Group: Members Posts: 875 Joined: 27-July 14 From: Wisconsin Member No.: 17,687 Region Association: Upper MidWest |
I just acquired another pair of 911 Bilstein struts (3.5 in. Bolt spacing on Caliper.)
Bilstein PN 911 341 041 30. All I come up with is a last numbers being 33 not 30. (IMG:style_emoticons/default/confused24.gif) I have used all the manuals, internet sources I have. Does anyone know for sure what year these would be from? I want to buy new rotors, wheel bearings etc for rebuild. Being I have 2 complete sets, will be selling the other set at some point. That set was identified as a 74’ in the 5lug classic thread. Strut #11700127363 Can post pictures if needed. |
mepstein |
Sep 11 2022, 02:06 PM
914-6 GT in waiting Group: Members Posts: 19,316 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Rotors depend on what calipers you are using.
I'm pretty sure there is just one size bearing and seals for the 3 1/2" struts. |
sixnotfour |
Sep 11 2022, 03:40 PM
914 Wizard Group: Members Posts: 10,436 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Replaces: 911-341-041-30, 911-341-041-32, 911-341-079-33, 911-341-079-36, 911-341-079-40, 911-341-079-48, 911-341-945-00
Sold In Quantity: 1 |
sixnotfour |
Sep 11 2022, 03:44 PM
dumpster diving ?? alot of shops replace the whole strut , if bushings are bad , or they are not aware you can replace insert.....I have 6 also , finally told the shop.. saves customers money..
Freezin 914 |
Sep 11 2022, 03:59 PM
Freezin 914 |
Sep 11 2022, 04:01 PM
dumpster diving ?? alot of shops replace the whole strut , if bushings are bad , or they are not aware you can replace insert.....I have 6 also , finally told the shop.. saves customers money.. Ha! If I knew of a place throwing these things away, I would be dumpster diving! Who knows what else they might be throwing away! Traded some parts for these, and purchased the other set. Thank you for the information. |
mepstein |
Sep 11 2022, 04:13 PM
Rotors depend on what calipers you are using. I'm pretty sure there is just one size bearing and seals for the 3 1/2" struts. Good to know about this. Pretty sure they are A calipers on them. I'm no expert. I think they are SC, right? 20mm Carrera calipers use 24mm rotors. |
sixnotfour |
Sep 11 2022, 05:03 PM
Rotors depend on what calipers you are using. I'm pretty sure there is just one size bearing and seals for the 3 1/2" struts. Good to know about this. Pretty sure they are A calipers on them. I'm no expert. I think they are SC, right? 20mm Carrera calipers use 24mm rotors. Doesnt matter ... Unless he has hubs and rotors.. |
Superhawk996 |
Sep 11 2022, 06:10 PM
914 Guru Group: Members Posts: 5,904 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
alot of shops replace the whole strut , if bushings are bad , or they are not aware you can replace insert. Please give that shop my contact information (IMG:style_emoticons/default/av-943.gif) |
sixnotfour |
Sep 11 2022, 06:26 PM
alot of shops replace the whole strut , if bushings are bad , or they are not aware you can replace insert. Please give that shop my contact information (IMG:style_emoticons/default/av-943.gif) Haha ,, ask Gary Emory, porsche filled dumpsters with old stock,, shops not in the know do the same.. |
Eric_Shea |
Sep 11 2022, 06:37 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
alot of shops replace the whole strut , if bushings are bad , or they are not aware you can replace insert. Please give that shop my contact information (IMG:style_emoticons/default/av-943.gif) Haha ,, ask Gary Emory, porsche filled dumpsters with old stock,, shops not in the know do the same.. Those stories brought a tear to my eye... but hey, that's how Parts Obsolete was born so, all good in the end. |
Freezin 914 |
Sep 11 2022, 06:54 PM
Rotors depend on what calipers you are using. I'm pretty sure there is just one size bearing and seals for the 3 1/2" struts. Good to know about this. Pretty sure they are A calipers on them. I'm no expert. I think they are SC, right? 20mm Carrera calipers use 24mm rotors. Doesnt matter ... Unless he has hubs and rotors.. Both sets have hubs, rotors, calipers. I am just figuring that bearings, and rotors need to be replaced and calipers to be rebuilt. |
Freezin 914 |
Sep 11 2022, 06:58 PM
This is the first set….
Attached image(s) |
sixnotfour |
Sep 11 2022, 07:03 PM
Rotor thickness is Key, Indicator...
Freezin 914 |
Sep 11 2022, 07:11 PM
The most recent set: 911 341 041 30
Attached image(s) |
Freezin 914 |
Sep 11 2022, 07:14 PM
sixnotfour |
Sep 11 2022, 07:15 PM
bearings seals the same
Lo-Fi Version | Time is now: 11th June 2024 - 09:47 AM |
