> OE (I think) voltage regulators, how to test before selling
fixer34
post Sep 13 2022, 01:50 PM
I bought the last solid state regulator Mark had hoping to solve my charging issues or at least eliminate it as the problem (can't get more than about 13v while running). I have 3 regulators that have been in the car over the years, but the last/newest one has been there for at least 20 yrs. I don't know if these are bad, good, or somewhere in between and I have no way of testing them. So no idea what they may be worth, if anything. Opinions?
Replies(1 - 6)
JamesM
post Sep 13 2022, 02:05 PM
QUOTE(fixer34 @ Sep 13 2022, 11:50 AM) *
Damn, You get 13v when running? Wish i had that!
No idea on bench testing.
Havent installed it yet but i picked up one of these adjustable regulators a few months ago just to see what it will do. I run AGM Odyssey batteries in all my 914s and they tend to like a little higher voltage than 914 provide stock.
https://www.ebay.com/itm/291674432232?fits=...%3ABFBMnOKWh-dg
emerygt350
post Sep 13 2022, 02:36 PM
I have a couple as well. Went to the hella solid state, 13.8 all day.
Geezer914
post Sep 13 2022, 04:22 PM
Geezer914
you can adjust these by bending the arm slightly. I have one that puts out 13.8 volts.
lesorubcheek
post Sep 13 2022, 05:41 PM
Here's a kinda neat setup for testing voltage regulators. Need a variable voltage DC supply that can exceed 14V and 12V light for an indicator, or you could substitute with another load meant to handle 12V and use a meter to measure the cutoff voltage.
https://www.thesamba.com/vw/forum/album_pag...?pic_id=1245795
Dan
fixer34
post Sep 13 2022, 06:27 PM
QUOTE(lesorubcheek @ Sep 13 2022, 06:41 PM) *
Dan
I'll have to try that on the ones I have. Will see how a 12v test lamp does, some other threads I found say the DF voltage is only 5 to 8/10v
lesorubcheek
post Sep 13 2022, 06:39 PM
QUOTE(fixer34 @ Sep 13 2022, 07:27 PM) *
It'll be interesting to hear how it works out. I've never dug into understanding charging circuitry beyond diodes in an alternator since that's about all I've ever had to repair.
Dan
- Lo-Fi Version Time is now: 11th July 2025 - 05:40 AM
