Pertonix/Compufire/Crane, Is it worth it? |
TravisNeff |
Aug 6 2005, 06:06 PM
Sure the pain in the ass factor of adjusting dwell and replacing points/condensors is just about worth the expense - but is there any other benefit to them (besides point bounce at high rpm)??
I have a dead CHT, so it's one of those while I am ordering things.... |
nsyr |
Aug 6 2005, 06:25 PM
Because I Can Group: Members Posts: 314 Joined: 16-May 04 From: Tampa, FL Member No.: 2,073 |
i just put in the crane xr700 in mine today and it does make it a better running engine. IMHO, ditch the points and convert, it's worth it.
tat2dphreak |
Aug 6 2005, 06:26 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
anything is better than points... but keep a spare set of points just in case... I use a compufire
Trekkor |
Aug 6 2005, 06:27 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
Do it!
Set and forget...Unless of course you install it wrong. (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) KT |
McMark |
Aug 6 2005, 06:55 PM
Electronic ignitions are less susceptable to distributor shaft wear. More smooth at higher RPM ranges. They boast of increased spark gap (ran my stock engine eith pertronix at 45 instead of 35). No maintenance.
Down side, they will burn out if you hook it up wrong, and they can die if the ignition is left on for long periods of time. |
markb |
Aug 6 2005, 07:11 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
I had a problem with the points closing up quickly. We put a crane in it and I (IMG:http://www.914world.com/bbs2/html/emoticons/wub.gif) it! I wouldn't go back. I do think I should carry a second dist in the trunk with a points setup, just in case, but then I was a boy sprout way back when. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Joe Bob |
Aug 6 2005, 07:56 PM
Allison/Crane....best bet.
Pertonix....suckz..... |
TravisNeff |
Aug 6 2005, 09:59 PM
That's good enough for me! The crane unit is double the price over the pertronics and compufire, any chebby places offer it for less (summit or whatever)??
Joe Bob |
Aug 6 2005, 10:03 PM
Yeah Summit and Pegasus are the best pricing....they sell them cheaper than what GPR and Pelican can get them for....
TravisNeff |
Aug 6 2005, 10:17 PM
Is the part number CRN-700-0231, they only list one unit for the XR700 points replacement. $90.99 at Summit
brp914 |
Aug 6 2005, 10:41 PM
Unregistered |
I put on a pertronix a few years ago. Simple install. No module, as opposed to others. If you get one with a module, dont mount on the engine. I went thru a couple of those years ago, back when they were Allison. The module cant handle the heat/vibration.
btw, you say your cht is bad. Had that happen, too. Isn't that weird? No moving parts. wtf? |
TravisNeff |
Aug 6 2005, 11:16 PM
No kidding, everytime I do a ohm test on it I get different results within a minute or so of each other. then finally it showed an open circuit.
Aaron Cox |
Aug 6 2005, 11:22 PM
PERTRONIX - awesome kit. drop in. drive off.
Crane takes forever to setup.... is this on a carbed motor? if it is, weigh the 80 bucks toward a mallory unilite...... AA |
TravisNeff |
Aug 6 2005, 11:54 PM
nope, fool injected
Rand |
Aug 7 2005, 12:30 AM
Ok, everything is perfectly clear now. (IMG:http://www.914world.com/bbs2/html/emoticons/Yack.gif)
Points aren't evil. They are easy to maintain, and they work just fine. Take care of them and they won't let you down. But yes, a modern ET system is potentially better. Glad that clears everything up. And now for something completely different. |
SLITS |
Aug 7 2005, 08:38 AM
Only for budding engineers like Brit and Aaron. |
rhodyguy |
Aug 7 2005, 09:20 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
wrong coil resistance may burn up the compufire. follow the instructions precicely. if you put one in and it cranks, and cranks, and cranks,... put the points back in.
k |
Aaron Cox |
Aug 7 2005, 09:52 AM
not hard to ohm your coil before you buy (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
rhodyguy |
Aug 7 2005, 10:11 AM
right aaron. just a heads up. i failed to due so and burned up $70 worth of a module when i was putting the 73' together. i spent 3 days chasing a "no start/no spark". the solder melted out of the bottom was appearent when i pulled it. couldn't see it when it was installed.
k |
Joe Bob |
Aug 7 2005, 10:54 AM
Ahhhh, ya let the magic smoke out..... (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 12:41 AM |
