I get a straggler spark to engine tin 74 2.0 |
scottsilvertt |
Sep 20 2022, 05:34 PM
scottsilvertt Group: Members Posts: 66 Joined: 17-May 06 From: South East USA Member No.: 6,019 Region Association: South East States |
Jett |
Sep 20 2022, 05:41 PM
Senior Member Group: Members Posts: 1,641 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
Hello, I get a straggler spark about every 15 seconds from the distributor cap to some engine tin. The tin is pretty close. 3/4 inch or so. Spark shown with a little lightning drawn on there. Should I take out my distributor, with the gear shaft, rotate counter clock one notch? Change the cap and leads? |
emerygt350 |
Sep 20 2022, 06:23 PM
Advanced Member Group: Members Posts: 2,147 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
I would check the plug too. That jump seems much harder than across the spark plug... Perhaps the wire isn't seated well.
porschetub |
Sep 20 2022, 06:35 PM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Hello, I get a straggler spark about every 15 seconds from the distributor cap to some engine tin. The tin is pretty close. 3/4 inch or so. Spark shown with a little lightning drawn on there. Should I take out my distributor, with the gear shaft, rotate counter clock one notch? Change the cap and leads? (IMG:style_emoticons/default/agree.gif) might pay to check the rotor as it will look crappy like the cap ,plugs etc so you are somewhat part of the way to doing an electrical ignition service. Things that come to mind including stuff mentioned above are ,leads,cap,rotor,points/ condensor,plugs,and then check the wiring to coil and condensor etc,reset the timing after. You have a high resistance on the lead shown as it is tracking to earth on the engine tin so most likely that lead is poo,you can still buy the Beru copper leads as you have now,but you can buy better ,good luck. |
mgphoto |
Sep 20 2022, 06:40 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Electricity will find the path of least resistance, so the gap between the insulated wire to the engine tin has less resistance than to that spark plug.
New wires, cap, rotor, points, condenser and spark plugs should cure the problem. |
Lo-Fi Version | Time is now: 11th June 2024 - 05:47 AM |
