help with oil leak, 2056 build |
Al Meredith |
Oct 23 2022, 10:46 AM
Senior Member Group: Members Posts: 960 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
I found my problem ! MY FAULT the thin aluminum gasket between the case and the cylinder was bent over and not sealing. I discovered the seal when I remover the cylinder . Everything good now, ran up the engine for 15 minutes and perfectly dry. My apologies to AA the cylinder was fine . The reason I was looking for something else is the fact that I have built dozens of ty4 over 30 years and never had this issue. MY BAD.
Superhawk996 |
Oct 23 2022, 11:23 AM
914 Guru Group: Members Posts: 5,892 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
(IMG:style_emoticons/default/aktion035.gif)
Thanks for closing out that oil leak thread. We’ve all been there and your posting will be a lesson to us all. Not only about how the littlest details matter but also the wisdom of doing initial start and cam break in on the test stand. What a PITA it would be to install into the car and then have to pull the engine. Been there done that! |
930cabman |
Oct 23 2022, 12:55 PM
Advanced Member Group: Members Posts: 3,144 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
I found my problem ! MY FAULT the thin aluminum gasket between the case and the cylinder was bent over and not sealing. I discovered the seal when I remover the cylinder . Everything good now, ran up the engine for 15 minutes and perfectly dry. My apologies to AA the cylinder was fine . The reason I was looking for something else is the fact that I have built dozens of ty4 over 30 years and never had this issue. MY BAD. Victory (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) Thanks for letting us know your outcome |
Lo-Fi Version | Time is now: 8th June 2024 - 05:22 AM |
