> It's not going to work out for me, is it?
redshift
post Aug 8 2005, 11:41 AM
Bless the Hell out of you!
I think I am about to lose another motor....
Valves were adjusted what.. 2 weeks ago, less even, and now it sounds like thumbing a hair comb, when you come off idle thru 1200-1300.. or thereabouts. I am beat. I can't make anything fail the same twice, and never on a meter.. last night I was sure I nailed down a CHT problem, today, it's fine. (should be.. it's new) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) Thing was tuned up 2 weeks ago, and ran for about 60 minutes since that time, without incident, otherwise..
3 motors, would that be a 20k record? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) I have put up in the 150k range, on more than one.
I see some liquor coming, when I scrape these 9 dimes together. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
M
Replies(1 - 19)
Andyrew
post Aug 8 2005, 12:04 PM
Spooling.... Please wait
Wait.... Your still running a stock motor??
Um.. You need a conversion. Remember my attitude with my engine? (I either need a full rebuild, or a new engine, so I'll just get a new engine....)
SGB
post Aug 8 2005, 12:19 PM
just visiting
Don't give up YET.
Wait until the drugs start to wear off. Then do some more. Just don't give up. There will always be more drugs.....
Uhhhh.
I know the car has FI, and I have zip/zed/zero experience with FI on a type-IV, BUT
When my weber equipped brigs & stratton x 4 made that binkibinkibinkibinkibinki sound, it turned out to be an intake valve opening too early. Compression test time?
redshift
post Aug 8 2005, 06:54 PM
Oh great! I'll just adjust it to open later. (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
(IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif)
M
SpecialK
post Aug 8 2005, 08:50 PM
aircraft surgeon
Hmmm...could it be possible one or more of the jamb nuts....uh, didn't? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
redshift
post Aug 8 2005, 09:06 PM
The problem that manifests itself as a sometime 'stumble' must also fail lean.. at higher ranges, I'd *imagine*, and cooks the heads. Theory.
I live too far away from Mecca, to make the Haj. The closest 914 pick-n-pull I know of, is about 2,219 miles away.
I don't want to put a radiator in this car. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
M
SpecialK
post Aug 8 2005, 09:44 PM
aircraft surgeon
It might be too late, but a good A/F mixture gauge, a CHT and/or EGT gauge might make some good troubleshooting instruments, or at least you could see the hammer getting ready to fall, and shut her down.
Bummer Miles...wish I lived closer, we could slap my gauges on there and see what's what. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
bd1308
post Aug 8 2005, 09:47 PM
Sir Post-a-lot
you're in savanna, GA.....thats like how far from Loueyville?
road trip!
i could bring my box too.
i dont know valve adjustments though.
i have parts.
Bleyseng
post Aug 8 2005, 09:50 PM
Aircooled Baby!
sounds like the DD problem that dropped two valve seats on him. Rich and Brad finally figured that out for him.
redshift
post Aug 8 2005, 10:17 PM
As ever, thanks for the moral support. The brittle sound of valves, make me gnash my teeth together.
After my recent experience, I understand why the relay box is considered to be the crossroads, of weakest links.
M
rick 918-S
post Aug 8 2005, 10:36 PM
Hey nice rack! -Celette
What motor are you running? If it turns out to be valves I have some core 1.7 heads you could have for the cost of shipping. They would need to be freshed but there next to free. Man your having a string of real bad karma.
redshift
post Aug 8 2005, 11:11 PM
It's a stock built 2.0, it's not something I think I care to work at, anymore.
My biggest problem... at the moment, is my other car is 2 hours away, and I don't have room to park it here, it can't even navigate my driveway.. =\
M
neo914-6
post Aug 8 2005, 11:19 PM
neo life
I can't take this defeatest attitude anymore. I will not come back on this board until you fix your car. Shall I say goodbye to everyone?
Was I gone long enough?
redshift
post Aug 8 2005, 11:25 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/happy11.gif)
People show up here, to the spider's lair, and they say, "Hey, I am a newbie! I found half of a rusted cowl in a field! Should I restore it! Convert it to a /6??"
And we push them!
Diabolical!
M
ChrisReale
post Aug 9 2005, 01:02 AM
Sleazy
Just yell "Im Miles Hendrix, Biatch" at it and that should straighten it out a bit.
redshift
post Aug 9 2005, 01:10 AM
I tried all my faces..
(IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) DAMNED YOU!
(IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) I DIN'T THINK YOU WERE A VERY GOOD MOTOR!
(IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) COME ON! WORK WITH ME!
(IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) WASSAT!?
(IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) OH MY GOD! NOT THAT WIRE AGAIN!
(IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) OUCH! DON'T TOUCH SPARK WIRE!!!
(IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif) Please, God, please... make it fall on me now..
(IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif) SEEMS OK!
(IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) NOOOOOOOOOOOOOO!
M
Tom Perso
post Aug 9 2005, 05:35 AM
Crazy from the Cold...
Can you pull all of your rockers off, then put a straightedge across all of the valves on each head? That way you can see if you're dropping a seat.
Then you can troubleshoot from there.
Also, you're running stock 2.0L rockers, right? Maybe swap over to the early 1.7L rockers and 911 adjusters. Should be a fairly easy in-car swap over...
Tom
balljoint
post Aug 9 2005, 06:26 AM
You forgot one.
(IMG:http://www.914world.com/bbs2/html/emoticons/sheeplove.gif) OKAY MOTOR NOW YOU'RE A GOAT....................AHHHHHHHHHHH IT BUUUURRRNSSSSS
you should have let it cool down first
redshift
post Aug 9 2005, 12:38 PM
LOL Dave!
Tom, all good stuff, will look it over. More from the driver's side, than the passenger side, more the rear, than the front.. definately valvetrain related... not the only problem.
(IMG:http://www.914world.com/bbs2/html/emoticons/sheeplove.gif) ouch.... (IMG:http://www.914world.com/bbs2/html/emoticons/sheeplove.gif) ouch....
M
MattR
post Aug 9 2005, 04:47 PM
Keep your head up buddy. If I had any ideas for your engine, i'd be glad to help, but there are much better engine gurus on the board. I just turn wrenches until it runs (and doesnt leak oil (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)).
Maybe a -6 would cheer you up?
- Lo-Fi Version Time is now: 11th July 2025 - 02:36 PM
