WTB. heat exchanger piece needed |
brant |
Nov 29 2022, 05:42 PM
914 Wizard Group: Members Posts: 11,626 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
not sure what to call this....
mine must have vibrated loose and fell off somewhere between colorado and SLC for the Red Rocks event.... does anyone have a spare to sell? its the cover plate that attaches to the S-bend on the rear attachment point to connect the HE with the S-bend for the heater system... thanks in advance here is the picture of the one plate I have.. and the smaller one I need. Attached thumbnail(s) |
PCA7GGR |
Nov 29 2022, 05:52 PM
Member Group: Members Posts: 251 Joined: 3-October 03 From: Dublin, CA Member No.: 1,219 |
914Sixer |
Nov 29 2022, 06:07 PM
914 Guru Group: Members Posts: 8,889 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Reproductions are available new. About $13. Heritage Parts Center
GaroldShaffer |
Nov 29 2022, 06:32 PM
You bought another 914? Group: Benefactors Posts: 7,623 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
There is a difference in size left VS right. Left side is 3 1/8 inches between hole centers VS 2 7/8 on the right side. Make sure you get the correct one. I too have these available.
brant |
Nov 29 2022, 06:44 PM
Thank you everyone
I need the drivers side small end I measured Hole to hole at 2 and 3/8 Pictures I should have taken earlier Attached thumbnail(s) |
brant |
And
brant |
Nov 29 2022, 06:47 PM
I should add
Used is fine for a driver car like this one |
PCA7GGR |
Nov 29 2022, 06:52 PM
Mine is 3 1/8 inches between hole centers.
brant |
Nov 30 2022, 08:01 AM
brant |
Dec 1 2022, 09:46 AM
bump...
still looking for the small end... driver side/Left Garold, sent you a pm to see if you have one for sale also brant |
brant |
Dec 2 2022, 07:39 AM
Still looking
Bump |
brant |
Dec 3 2022, 08:02 AM
Weekend bump
TheCabinetmaker |
Dec 3 2022, 08:16 AM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I might have one, Brandt. I'll look in a bit
TheCabinetmaker |
Dec 3 2022, 10:17 AM
brant |
Dec 3 2022, 11:42 AM
Curt
Thank you so much It’s hard to tell length in a photo Would you also mind checking the length between the bolt holes? The one I need goes on the rear of the S connector with 2 and 1/4 bolt spacing Thank you against n Curt I’m excited to put things back together and move to the next project on the list |
TheCabinetmaker |
Dec 3 2022, 12:21 PM
Brandt, the holes are 3⅛ inches on center. It came off the the driver's side pipe from the fan shroud. I have a pair of repops. Neither are 2¼ inches
brant |
Dec 3 2022, 12:33 PM
No problem Curt
Mine takes that size on the fan shroud end too But the smaller size on the end that connectsn to the HE I’m guessing it’s the small one that frequently vibrates loose and gets lost (like mine) Where did you buy the repops? Looks like I need to do that The link in this thread is in Europe…. So I’ll see if there is a US option that doesn’t want more for shipping than the part costs |
TheCabinetmaker |
Dec 3 2022, 12:44 PM
Gotcha. The other end is just a piece of bent sheet metal. It's not like the shroud end. I'm not home till later. I'm sure to have one.
brant |
Dec 3 2022, 12:53 PM
GaroldShaffer |
Dec 4 2022, 08:33 AM
I need to work on my reading comprehension. This is what your are looking for?
Attached thumbnail(s) Attached image(s) |
Lo-Fi Version | Time is now: 23rd May 2024 - 03:33 PM |
