| brant |
Dec 8 2022, 06:07 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,217 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
Any one know which way to orient the caliper piston on 911 A calipers?
My right and left sides are 90 degrees different from each other I’m doing a maintenance rebuild and I assumed I could put the pistons back as before until I found the RF to be different than LF Picture of the cut edge: Attached thumbnail(s) |
| Eric_Shea |
Dec 8 2022, 07:06 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
The 20° Notch will face upward toward the bleeder on each one. I don’t have the graphic on my phone right now. I’ll load it when I get to a PC
| brant |
Dec 8 2022, 07:11 PM
| Eric_Shea |
Dec 8 2022, 07:43 PM
The 20° Notch will face upward toward the bleeder on each one. I don’t have the graphic on my phone right now. I’ll load it when I get to a PC Thank you sir! Not urgent Hey.. maybe steamboat next September Nice drive through dinosaur! I’ll send you a pair tomorrow. 20mm vented rotors correct? Steamboat sounds great. (IMG:style_emoticons/default/smilie_pokal.gif) |
| brant |
Dec 9 2022, 10:00 AM
Correct
20mm vented Is it a PDF or template? I assume |
| PatMc |
Dec 9 2022, 11:10 AM
Member ![]() ![]() Group: Members Posts: 121 Joined: 27-June 21 From: Long Beach Member No.: 25,669 Region Association: None
Here you go
| Eric_Shea |
Dec 9 2022, 11:41 AM
Correct 20mm vented Is it a PDF or template? I assume Leave them. I have a set coming your way. Late RRC prize winner (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 23rd June 2026 - 03:33 PM |
