> valve spring compressor needed, recommendations
rfinegan
post Dec 13 2022, 06:08 PM
I need to pull the valves and double valve spring out of my T4 heads.(heads off engine) What spring compressors are people using and can recommend ?
Replies(1 - 6)
Montreal914
post Dec 15 2022, 09:19 AM
brant
post Dec 15 2022, 09:31 AM
25 years ago...
we just made one.
a flat stock bar about 1.25 inches wide... with a fork tongue on the end to fit around the stem... ours bolts onto the rocker stand posts, when the rockers are removed.
Superhawk996
post Dec 15 2022, 11:40 AM
Similar
I use a giant c-clamp with a custom lathe turned end that allows me to fish out the keepers after the valve spring retainer has been compressed.
Any commercially available unit that is appropriately sized for automotive ought to do the trick.
Sorry - no picture quickly available
914sgofast2
post Dec 15 2022, 01:27 PM
Someone in the Samba.com Classifieds section sells a Type 4 valve spring compressor tool for around $90.
nathanxnathan
post Dec 15 2022, 03:24 PM
I've used style they say is for type 1 on type 4 heads plenty of times. It would be nice to have one that's similar to the factory style, as the bench top ones are bulky to store compared to the ones that bolt to the rocker studs.
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.heritagepartscentre.com-21899-1671139459.1.jpg)
barefoot
post Dec 16 2022, 03:22 PM
Got this on Amazon
I made a spacer to fit out retainer better & had to make an extension handle to get enough leverage even for stock single springs, but it worked fine.
- Lo-Fi Version Time is now: 1st May 2026 - 02:36 AM
