Door latch adjustment, How to do it |
jdamiano |
Dec 24 2022, 10:05 AM
Member Group: Members Posts: 335 Joined: 18-March 18 From: Jacksonville Member No.: 21,981 Region Association: South East States |
Seems my passenger door isn’t latching properly all of a sudden. I really have to slam it for it to latch. The latch works fine if I flip it by hand. It’s seems like I need to move them closer together. The screws loosened right up but there didn’t seem to be any adjustment. Any advice is appreciated.
Lockwodo |
Dec 24 2022, 10:21 AM
Member Group: Members Posts: 201 Joined: 23-December 21 From: Santa Cruz, Californnia Member No.: 26,193 Region Association: Northern California |
Try lubricating the latch mechanism first.
jdamiano |
Dec 24 2022, 10:26 AM
I think I got it. I took the jam piece off and cleaned it up then used more force then I wanted to to push it out while tightening it down.
Cairo94507 |
Dec 24 2022, 10:43 AM
Michael Group: Members Posts: 9,808 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Take a look at your suspension console too.... just in case. (IMG:style_emoticons/default/beerchug.gif)
URY914 |
Dec 24 2022, 02:54 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,944 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
^^^This.
The underlaying issue with 914 door problem and the first thing to break will be the door handle. Be careful. I can repair the flapper if it breaks. |
mlindner |
Dec 26 2022, 01:29 PM
Senior Member Group: Members Posts: 1,525 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
And how does the door fit with rear fender edge...Door should be out just a little protecting fender edge from stones etc.
TheCabinetmaker |
Dec 26 2022, 01:43 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
You should also remove the latch in the door and thoroughly clean and relube it. It's the major cause of broken door handles.
Lo-Fi Version | Time is now: 31st May 2024 - 10:33 PM |
