UkonCornelious |
Newbie ![]() Group: Members Posts: 16 Joined: 10-February 21 From: Richmond, VA Member No.: 25,192 Region Association: Middle East ![]() |
I'm trying to figure out the correct clips to buy to secure the door handles through the door panels. The original clip has broken and I want to buy a few replacements.
I believe this is what I'm looking for, but I'm not sure if it's the right clip. https://914rubber.com/fog-light-grille-speed-clip-1 Anyone have a part number or good replacement for these? |
Rob-O |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,274 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region ![]() ![]() |
I don’t have a part number handy but the part in your link is not correct. I’m sure someone will be around soon to tell you they have three hundred and twenty six of those things in a jar in their garage…and would be happy to send you a half dozen if you PM them your address.
Just watch. It’ll happen. That’s how this site works… |
UkonCornelious |
Thanks for the quick response! I didn't think they were right, but they look similar to what I need.
They're the little ones that the door panel bolts secure to (where the door handle secures). Hopefully, that was clear as to what I'm looking for. |
windforfun |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,057 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None ![]() ![]() |
UkonCornelious |
Thanks! #18s!
bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
They are called cage nuts. Pretty standard hardware available at belmetric, Mcmaster-Carr, etc. Possibly even at your local hardware or FLAPS. IIRC, M6 for the door pulls. And allen socket head screws for the fasteners.
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,188 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
there are early longer ones, 70-74 and later shorter ones 75-76 you can see the two different part numbers on our factory hard parts drawings
I'm trying to figure out the correct clips to buy to secure the door handles through the door panels. The original clip has broken and I want to buy a few replacements. I believe this is what I'm looking for, but I'm not sure if it's the right clip. https://914rubber.com/fog-light-grille-speed-clip-1 Anyone have a part number or good replacement for these? |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
We have them, they are also used on the passenger side door panels. I'll have Blake list them up.
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,739 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
bbrock |
We have them, they are also used on the passenger side door panels. I'll have Blake list them up. Mark @Mikey914 and George @dr914 @autoatlanta.com, are those the same as BelMetric and others sell? If so, they are slightly smaller and don't want to stay in place. Interesting. I've had good luck with the belmetric clips but occasionally find one that fits loose. I've had good luck prying the prongs out a bit to get theme to "clamp" in place. |
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,384 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
Try your local ACE Hardware. I sourced these from a member and then found them new at ACE. (IMG:style_emoticons/default/beerchug.gif)
76-914 |
We have them, they are also used on the passenger side door panels. I'll have Blake list them up. Mark @Mikey914 and George @dr914 @autoatlanta.com, are those the same as BelMetric and others sell? If so, they are slightly smaller and don't want to stay in place. Interesting. I've had good luck with the belmetric clips but occasionally find one that fits loose. I've had good luck prying the prongs out a bit to get theme to "clamp" in place. @bbrock Interesting Brett. I see the Doc says there are 2 sizes. Maybe that was the difference. Yes, I bent the ears out but it would never stay in place because the ears went from parallel to a "V" shape and/or broke an ear when futzing with one. I found one from Bruce finally. In hind site I believe I should have made a 1" square of some 20ga with an opening sized for the BelMetric piece then welded that piece to the door. (IMG:style_emoticons/default/headbang.gif) |
we have both the cage nuts for the drivers side *5mm) as well as the rivet on plate with cage nut for the passenger side
Mikey914 |
We have them, they are also used on the passenger side door panels. I'll have Blake list them up. Mark @Mikey914 and George @dr914 @autoatlanta.com, are those the same as BelMetric and others sell? If so, they are slightly smaller and don't want to stay in place. We actually made our own, so we are not reselling. |
Lo-Fi Version | Time is now: 13th July 2025 - 07:57 PM |
