| tdgray |
Aug 10 2005, 09:51 AM
Thank God Nemo is not here to see this ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,706 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
So I figure I better start contributing with some real content rather than stupid jokes and snide remarks. So here goes.
I purchased my 1973 1.7L for $300.00. Damn good thing to because there was about 8 thousand times the rust that I could see (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) (duh!) Before I tore the car apart I got the engine running. PO said fuel pump was bad. Turned out the relay was bad and in his attempts to fix the problem he reversed the fuel lines. Put a new relay fired right up...ran like crap but still it ran. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) After stripping all interior, electrical and accesories from the car the real work started. Nothing more than expected just a long list. Some of the problem area identified. 1) Rust in longs 2) Rear trunk and valance panel totally rusted out 3) Floorboards very rusted out - quite a few holes 4) Sill plates and door jams very questionable 5) Typical battery tray and engine shelf damage 6) Front trunk rusted around AC unit 7) Sail panels - bad PO repair with Bondo Just one note for the rest of this, I am not CptTripps... these pic's are over a years time span. The reason I am finally posting all this is to motivate me to get 'er done. It may not be realistic but I am still shooting for the FFC this year. I really have to get moving NOW! |
| tdgray |
Aug 10 2005, 09:52 AM
First task at hand was to cut the trunk and valance panel out. Lid was scrap. Got a few used pieces for replacement.
| tdgray |
Aug 10 2005, 09:53 AM
All buttoned up... still needs finishing and rear trunk pan.
| CptTripps |
:: Punch and Pie :: ![]() ![]() ![]() ![]() Group: Members Posts: 3,585 Joined: 26-December 04 From: Tuscaloosa, AL and Akron, OH Member No.: 3,342 Region Association: Upper MidWest |
Man...you really have your work cut out for you...(No pun intended)
We'll motivate you...just you wait. |
| tdgray |
Aug 10 2005, 09:54 AM
Next Task...
Drop the engine. Easy job took my brother and I about three hours. Attached image(s)
| tdgray |
Aug 10 2005, 09:55 AM
Damn that engine looks big when it is not in the car
| tdgray |
Hell Hole after engine removal (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
| tdgray |
Aug 10 2005, 09:56 AM
Big Problem when removing the engine... had to cut the engine bar. YIKES (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif)
| tdgray |
Aug 10 2005, 09:57 AM
Next Task.
Longs are solid but have some major patches of rust. Cut it out and patch new metal in. Oh the carnage Attached image(s)
| tdgray |
Aug 10 2005, 09:59 AM
Thanks to Dr. Evil for the clam shells... Just what the Dr ordered. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
A little test fitting Attached image(s)
| tdgray |
Aug 10 2005, 10:00 AM
My buddy Dave (acting like a dork). Leveling the car before welding the clams on.
| tdgray |
Aug 10 2005, 10:01 AM
Finished Welding... still a little clean up to do but that will come soon.
| tdgray |
Aug 10 2005, 10:02 AM
Other side... rust was not as bad. Less patching to do Clam ON
| tdgray |
Aug 10 2005, 10:04 AM
Stripped Down. Doors and targa off now that I trust the frame rigidity. Ready for sills and door jambs.
| tdgray |
Aug 10 2005, 10:05 AM
Door jamb carnage. Also firewall damage along with inner fender damage.
| tdgray |
Aug 10 2005, 10:07 AM
Cut the door jamb out. Normally you would pull the fender. I decided not to mess with aligning the fender etc. My plan was to grind out the old and smooth in the new.
| tdgray |
Aug 10 2005, 10:08 AM
Firewall and inner fender repairs... no making fun of my welds please (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
| tdgray |
Aug 10 2005, 10:10 AM
New door jambs. I test fit these suckers about a million times. Normally they fit in behind the fender. I fit the flush with the fender. No problems with door clearance.
| tdgray |
Aug 10 2005, 10:12 AM
Next new door sills. Pretty easy installation.
| tdgray |
Aug 10 2005, 10:13 AM
Test fitting donor lower fender. Original was absolute shit
Lo-Fi Version | Time is now: 2nd April 2026 - 07:17 PM |
