blower heater engine compartment |
Petepat |
Jan 14 2023, 06:21 AM
Member Group: Members Posts: 60 Joined: 1-December 19 From: Florida Member No.: 23,691 Region Association: None |
Anyone know where I could buy a new or reconditioned blower heater for rear engine compartment or better still a re-con kit as the main bush/bearing is shot. I can see plenty of blowers for the front but not back. Thanks in advance.
930cabman |
Jan 14 2023, 07:26 AM
Advanced Member Group: Members Posts: 3,169 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
You might find a small motor shop and rebuild, most of these are easily rebuildable and save $$
rhodyguy |
Jan 14 2023, 10:02 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,097 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
There are 2 styles. The single outlet that has it’s own bracket that’s welded to the shelve and the dual outlet that mounts on the engine shroud. Which style do you need?
Petepat |
Jan 14 2023, 10:51 AM
914sgofast2 |
Jan 14 2023, 12:52 PM
Senior Member Group: Members Posts: 623 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
I believe the fan’s motor itself is the same as used on VW Bay Window buses from 1972 to 1979 that had the Type 4 engines.
Petepat |
Jan 15 2023, 10:00 AM
Lo-Fi Version | Time is now: 12th June 2024 - 06:33 PM |
