orangecrate |
Member ![]() ![]() Group: Members Posts: 169 Joined: 16-September 13 From: Apache Junction AZ Member No.: 16,394 Region Association: Southwest Region ![]() |
You have a 72, rebuilt engine and trans , new shocks-struts, good rubber, rebuilt brakes, stainless fuel lines, converted fuel pump, solid body. basicly a stocker in good shape. You're gonna take a trip from Phoenix to Birmingham. And back. Days of slightly illegal speed. What would you bring? What would you do to prepare besides oil change , valve adjustment, the obvious stuff?? In search of the dream. After all , a teener is nothing if not a touring car, is it not? (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/biggrin.gif)
NARP74 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,416 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains ![]() |
Have you done a few local shakedown runs and then a bolt check and torque of critical items?
sb914 |
Surf Guru ![]() ![]() ![]() ![]() Group: Members Posts: 4,530 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California ![]() ![]() |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,329 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
![]() (IMG:style_emoticons/default/agree.gif) Or you can do the spare parts thing and try to bring one of everything that could possibly fail. Don’t forget all the tools you might need. Car will be 300 lbs heavier, slower, and will have to work harder to get to your desired speed. Might just as well tow the spare parts car with you. (IMG:style_emoticons/default/laugh.gif) Shake it down we’ll with lots of local mileage and you’ll be fine. |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,043 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
My road trips are 1-2x a year
Thousand miles each An alt. Distributor. Starter. Spare fuel injection Including ECU injectors. Fuel pump. MPs. Cht. points for fi Regulator board and regulator Plus drive axle wheel with 2 cv’s Rear wheel bearing Front bearings Ignition switch Alt harness Lots of Tools. Hardware. Timing lamp Cables Jack and stand Full size spare Battery charger Extension cord Etc Etc Everything Attached thumbnail(s) ![]() |
Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,899 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
Get the 200mi AAA plan. Bring along a few light parts and basic tools.
Share you route here so that members are aware of your travels. Chances are you might be within a 200mi reach of friendly support if you ever needed it! (IMG:style_emoticons/default/smilie_pokal.gif) Get on the road mind free, take pictures and share here as you drive along! (IMG:style_emoticons/default/driving.gif) |
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,233 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
I took a shakedown last fall, about 800 miles total. Near the onset I was hearing a rattling in the drivers front corner, it go so bad I pulled into a Lowes parking lot with basically no tools. Got her up in the air and noticed the drivers front caliper was being held on with one (loose) bolt. Luckily Lowes had what I needed and got on my way quickly.
My advice is check all major bolt on components for tightness, basic tools and plenty of room on your plastic. |
StarBear |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,187 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States ![]() ![]() |
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,421 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
If you have done several shake-down trips and had no issues, I would just crawl under the car and check everything for tight, check all 4 tires for nails, etc., check brake fluid, check transaxle fluid, top-off oil and bring a couple extra quarts, alternator belt, throttle cable, clutch cable, check all lights, spare fuses, electrical tape, flashlight, road flares, some wire, cash, 200 Miler AAA card- (worth its weight in gold) and have your route well planned out and try to ID Porsche shops along the way- just in case. Oh, and have a great trip. (IMG:style_emoticons/default/beerchug.gif)
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
If you have done several shake-down trips and had no issues, I would just crawl under the car and check everything for tight, check all 4 tires for nails, etc., check brake fluid, check transaxle fluid, top-off oil and bring a couple extra quarts, alternator belt, throttle cable, clutch cable, check all lights, spare fuses, electrical tape, flashlight, road flares, some wire, cash, 200 Miler AAA card- (worth its weight in gold) and have your route well planned out and try to ID Porsche shops along the way- just in case. Oh, and have a great trip. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/agree.gif) A nice empty CC for an emergency hotel. AAA |
orangecrate |
orangecrate |
(IMG:style_emoticons/default/laugh.gif) Ya .. while traveling in my CJ 5 with "race seats" we stopped at an ACE and got some gardeners knee cushions. Worked great. |
mlindner |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,698 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest ![]() ![]() |
Map out your route, then ask what teeners are close if you need help (Lift).
Jett |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,685 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest ![]() ![]() |
Already mentioned, but full nut/bolt tightening, and make sure you have the AA card.
Sounds like a blast |
Aerostatwv |
Member ![]() ![]() Group: Members Posts: 148 Joined: 13-July 11 From: WV Member No.: 13,315 Region Association: MidAtlantic Region ![]() ![]() |
BMW Motorcycle Owners Association used to publish a book for members that listed other owners and available capabilities in case you needed someone to call for help. Something like that would be awesome in the 914 world. I would gladly lend any support to a fellow teener in need.
I had the motor and transmission out of my car for a total re-seal last year. Got the driveline reinstalled on a Sunday, got the car running Wednesday evening, jumped in it the next day and drove to Okteenerfest 7 hours away. Car ran flawlessly to, during, and from the event all the while getting 30mpg. My thoughts on carrying lots of tools, I'm usually close to a u-haul dealer anywhere I go.. I still carry the basics, i.e. handtools, a good jack, flashlights, etc. Part of owning these cars is the actual road trip adventures. Chris |
808 WRX |
Member ![]() ![]() Group: Members Posts: 60 Joined: 4-June 20 From: San Jose, CA Member No.: 24,349 Region Association: Northern California ![]() ![]() |
Besides the AAA card and basic tools, I would bring a tire plug kit and a small air compressor.
troth |
Member ![]() ![]() Group: Members Posts: 160 Joined: 17-August 16 From: CT/WA Member No.: 20,305 Region Association: None ![]() |
Earplugs.
914-300Hemi |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,389 Joined: 7-September 06 From: San Dimas, CA Member No.: 6,794 Region Association: Southern California ![]() ![]() |
Voltage regulator and some basic tools.
Enjoy the drive. |
emerygt350 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,177 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States ![]() |
Yeah, a small tool kit, canoair, and just go. You should know if the cars gonna make it. I would cross the country in mine without a second thought, but I know it pretty well by now. It also wasn't recently rebuilt (or ever, that I know of). That's the only thing that would make me nervous. If you have done your own brakes, know your suspension, your tires are good, the rest should be fine. Truthfully, this era of electronics do better with use. I have a 1973 fender twin reverb, all original. Playing it every couple of days is what keeps it happy.
That said, this is exactly why I have more gauges than God in my 914. I want to know if it's starting to do something outside of normal before it becomes a triple a moment. I know, in most cases of something happening it will be triple a, but at least with good info on temp (cht and oil), oil pressure, and voltage you can glance down and know all is good and relax and enjoy the drive. |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,240 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Ear plugs.
A cooler with some ice, a bunch of water, maybe some caffeinated drink. A hand towel or dish towel. In the summer, toss the towel in the cooler with the ice--some of which will be water. Put the wet towel around your neck to cool off. Recharge the towel when you start feeling warm again. That setup (I used a washcloth and wanted a larger towel, which is why I recommend a hand towel or dish towel) is how I got through the Nevada desert in late June. --DD |
Lo-Fi Version | Time is now: 29th August 2025 - 04:54 PM |
