Wiring behind the dash., two wires with no home |
nivekdodge |
Jan 21 2023, 05:11 PM
Member Group: Members Posts: 250 Joined: 28-August 21 From: Pittsburgh Pa Member No.: 25,860 Region Association: MidAtlantic Region |
I have two wires behind the hazard switch and the multi gauge with no connection. These spade lugs appear to be factory but are side lugged (wire comes in from the side)not the back. Grey w red and Brown? turn signal? They can only go were they reach and there is no spade to push them on.????? Anyone have a lead ???
Kevin |
JeffBowlsby |
Jan 21 2023, 05:28 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Check the schematic for your
Model year |
Puebloswatcop |
Jan 21 2023, 06:28 PM
Senior Member Group: Members Posts: 1,389 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region |
I have two wires behind the hazard switch and the multi gauge with no connection. These spade lugs appear to be factory but are side lugged (wire comes in from the side)not the back. Grey w red and Brown? turn signal? They can only go were they reach and there is no spade to push them on.????? Anyone have a lead ??? Kevin Need the year of the car, can you get a pic of what you're describing? |
davep |
Jan 21 2023, 06:29 PM
914 Historian Group: Benefactors Posts: 5,152 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
If you mean flag connectors, then they should be 2 of the 3 wires that go to the fog light switch.
nivekdodge |
Jan 21 2023, 07:08 PM
Root_Werks |
Jan 23 2023, 11:36 AM
Village Idiot Group: Members Posts: 8,337 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
If you mean flag connectors, then they should be 2 of the 3 wires that go to the fog light switch. (IMG:style_emoticons/default/agree.gif) Just installed the Fog switch on my 75'. Can't recall the colors. |
davep |
Jan 23 2023, 08:22 PM
The third wire is a Black/ blue stripe from terminal 56 on the headlight switch.
nivekdodge |
Jan 23 2023, 11:04 PM
The third wire is a Black/ blue stripe from terminal 56 on the headlight switch. (IMG:style_emoticons/default/smile.gif) Thanks again dave |
930cabman |
Jan 24 2023, 05:49 PM
Advanced Member Group: Members Posts: 3,146 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Lo-Fi Version | Time is now: 9th June 2024 - 01:41 PM |
