Door Panel Dimensions |
mmascari |
Jan 24 2023, 09:11 PM
Member Group: Members Posts: 321 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None |
I picked up some door panels and need to cut holes for the door handle. Does anyone have dimensions from bottom/top and from the front of the panel to cut? Thank you
Mikey914 |
Jan 24 2023, 10:25 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Should be able to flip over old panels and use as a template.
mmascari |
Jan 24 2023, 10:59 PM
I was able to figure it out. I didn't have old panels but I just measured from the front and bottom of the door and just cut and checked until the holes were perfect.
dr914@autoatlanta.com |
Jan 25 2023, 11:22 AM
914 Guru Group: Members Posts: 7,893 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
early panels are smaller than the later ones: 8/69- about 8/72 were the smaller and 9/72-12/75 were the later ones
I picked up some door panels and need to cut holes for the door handle. Does anyone have dimensions from bottom/top and from the front of the panel to cut? Thank you |
jaredmcginness |
Jan 26 2023, 06:59 AM
... Group: Members Posts: 502 Joined: 12-June 19 From: Baltimore Member No.: 23,209 Region Association: MidAtlantic Region |
Here is my sketch from a few years ago for the panels I made for my early ('71) car.
Once foamed and lined they look great - but beware, I believe they were a tad off on some measurements. Unfortunately I cannot remember which. (P.S. this is only for the bottom portion, I drilled holes for the mounting tabs of the top cushion piece) also the length of the handle slot is 4.14" (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-23209-1674737987.1.jpg) |
Lo-Fi Version | Time is now: 6th June 2024 - 11:47 AM |
