door handle trim screws |
Medtner3 |
Jan 27 2023, 05:02 PM
Member Group: Members Posts: 180 Joined: 7-July 20 From: Cedar Park Member No.: 24,467 Region Association: None |
I'm looking for the tiny screws that hold on the plastic door handle trim. I know that they are very small but I don't think I have the correct screws. Also, does anyone know if that is supposed to have a washer? it looks like it would be a screw with a tapered head.
Thanks |
Medtner3 |
Jan 27 2023, 07:57 PM
I'm looking for the tiny screws that hold on the plastic door handle trim. I know that they are very small but I don't think I have the correct screws. Also, does anyone know if that is supposed to have a washer? it looks like it would be a screw with a tapered head. Thanks |
Puebloswatcop |
Jan 27 2023, 07:58 PM
Senior Member Group: Members Posts: 1,389 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region |
I'm looking for the tiny screws that hold on the plastic door handle trim. I know that they are very small but I don't think I have the correct screws. Also, does anyone know if that is supposed to have a washer? it looks like it would be a screw with a tapered head. Thanks That screw is an m5 X 12 mm long with a countersunk (tapered) head. It does not have a washer. The part # is 900 147 004 02. According to Porsche it is no longer available. I'm sure someone can help you find a couple, or if you have a wrecking yard that deals in VWs and Porsches, you could dig some up there. |
Medtner3 |
Jan 28 2023, 08:40 PM
I'm looking for the tiny screws that hold on the plastic door handle trim. I know that they are very small but I don't think I have the correct screws. Also, does anyone know if that is supposed to have a washer? it looks like it would be a screw with a tapered head. Thanks That screw is an m5 X 12 mm long with a countersunk (tapered) head. It does not have a washer. The part # is 900 147 004 02. According to Porsche it is no longer available. I'm sure someone can help you find a couple, or if you have a wrecking yard that deals in VWs and Porsches, you could dig some up there. Thanks I figured out that it was m5 and was able to find it at my hardware store |
Lo-Fi Version | Time is now: 9th June 2024 - 02:04 AM |
