> Quick release hubs
BillJ
post Jan 28 2023, 11:01 AM
What are the racers using these days for quick release hubs? I have a setup with a dual pull pin setup but sometimes it binds and i want to refresh it. I have an original 6 so a different steering column and spline so want to see specifically for theat equipment.
Looking for excellent no fail designs where cost isnt the biggest factor.
Replies(1 - 7)
sixnotfour
post Jan 29 2023, 06:28 PM
Rothsport Racing. makes one based on the Porsche one they used... https://rothsport.com/collections/quick-rel...ering-hub-clear
BillJ
post Jan 29 2023, 07:52 PM
Will check it out!
BillJ
post Feb 18 2023, 04:24 PM
Ok so i found what i needed. Rennline makes a very short hub converter. Have it in hand and all is well. Just got.the old one off and have a question.
Should the steering shaft have any play? I am getting a good amount of deflection something like 1/2 inch if i had to guess. Is thhere a bushing i should insert before putting this back together?
BillJ
post Feb 18 2023, 04:40 PM
Nevermind. Once the hub adapter went in the flange pressed into the bushing and it is now snug.
sixnotfour
post Feb 19 2023, 02:10 PM
Huck271
post Feb 19 2023, 05:09 PM
QUOTE(BillJ @ Feb 18 2023, 04:40 PM) *
Is your steering wheel centered over the driver seat?
BillJ
post Feb 19 2023, 11:22 PM
Using the stock location and rails so no the wheel sits a couple inches to the riight.
- Lo-Fi Version Time is now: 11th May 2025 - 05:23 PM
