Deusexmachina77 |
Member ![]() ![]() Group: Members Posts: 93 Joined: 30-March 22 From: Chicago Member No.: 26,426 Region Association: Upper MidWest ![]() ![]() |
I have a 76'.
I am in the process of replacing the struts and have decided to replace the tie-rods as well since the joints are trashed. I want to pull the steering gear out so I can work on a bench and not under the car. I studied @IanKarr video https://www.youtube.com/watch?v=MnuYLbZ89y8 but doesn't show it being removed. I can not see a way to remove it without removing a lot of parts of the suspension. In the Hanes manual, you have to remove the auxiliary carrier. (Page 103), Section 10, Removing the auxiliary carrier, Step 5. "Remove the torsion bar adjusting screws then pull off the adjusting levers and seals." I have no clue what this means and could use some instruction. (IMG:style_emoticons/default/confused24.gif) Thank you in advance. Victor |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,513 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
They're referring to the torsion bars. (IMG:style_emoticons/default/beerchug.gif)
zoomCat |
Member ![]() ![]() Group: Members Posts: 162 Joined: 13-August 04 From: Cincinnati, OH Member No.: 2,526 Region Association: None ![]() ![]() |
Deusexmachina77 |
So, Step one: remove the torsion bar. |
Deusexmachina77 |
zoomCat |
I'm at my limits of my knowledge. This may be more informative than the Haynes manual, but unfortunately I haven’t any first hand knowledge of what you’re doing. http://p914-6info.net/PDFs/Group%204%20Front%20Axle.pdf |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,098 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
Are you replacing the tie rods and ball joints? There’s no need to pull the rack unless it needs work. Do one task, the strut cartridges, (contrary to what you might read in the Haynes) the strut housings remain on the car when the swap is performed, button it up and move on to the tie rod items. You don’t need to touch the height adj for any of it unless doing the control arm bushings. You set the height prior to the in the future 4 wheel alignment.
fixer34 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,098 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest ![]() ![]() |
The AI instructions didn't tell you what to do?? Sorry, I couldn't resist...
So tell us again what you want to do (or think you want to do). Replacing the struts does not require removing the steering rack. You may or may not have to remove the control arms depending on whether you can separate the lower ball joint from the control arm. If you want to take each side off, first remove the caliper. You will need to separate the brake line because it runs thru a retainer on the strut. Do it quick and you won't lose much brake fluid. Then pop the tie rod end out. The torsion bar adjusting screw (bolt?) needs to be backed out to remove the downward tension. If I recall, there are 2 mounting bolts in the front and two in the rear. Remove those and the upper strut nut and it comes out in your hands. Where in Chicago/area are you? I'm in NW suburbs. |
NARP74 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,075 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains ![]() |
I did mine without removing the rack. A little more tedious but everything is when you are under the car on the floor.
Deusexmachina77 |
The AI instructions didn't tell you what to do?? Sorry, I couldn't resist... So tell us again what you want to do (or think you want to do). Replacing the struts does not require removing the steering rack. You may or may not have to remove the control arms depending on whether you can separate the lower ball joint from the control arm. If you want to take each side off, first remove the caliper. You will need to separate the brake line because it runs thru a retainer on the strut. Do it quick and you won't lose much brake fluid. Then pop the tie rod end out. The torsion bar adjusting screw (bolt?) needs to be backed out to remove the downward tension. If I recall, there are 2 mounting bolts in the front and two in the rear. Remove those and the upper strut nut and it comes out in your hands. Where in Chicago/area are you? I'm in NW suburbs. @fixer34 Good one (IMG:style_emoticons/default/laugh.gif) I'm in Mt. Prospect. This is my first 914 and the first car I have ever attempted to work on. So, I really have no clue what I'm doing. (IMG:style_emoticons/default/confused24.gif) I set out to refresh the front struts. They were shot. The driver-side ball joint was split as was the tie-rod end. The passenger side wasn't as bad but I planned to replace both sides. I was going to upgrade to Turbo tie-rods. This is where I came off the rails. Unfortunately, I watched the video I referenced. That video skips over the removal of the support rack (not sure what to call it). That is when I wrote my post. I was really lost. I've reversed my decision on the Turbo-tie rods since I posted. It's just too damn cold in my garage and my old bones can't take it. So, for now, I'm just changing the ends of the tie-rods. So once my parts get here I'm just hoping I can get everything back together (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/driving.gif) |
Deusexmachina77 |
I'm at my limits of my knowledge. This may be more informative than the Haynes manual, but unfortunately I haven’t any first hand knowledge of what you’re doing. http://p914-6info.net/PDFs/Group%204%20Front%20Axle.pdf (IMG:style_emoticons/default/beerchug.gif) |
Van B |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,613 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None ![]() ![]() |
Seems to me that you see what needs to be done… all while hoping there’s a way to not do it that way lol. I think you’ve got the right material, now you just need to commit to the idea you are a classic car owner!
Sometimes you’ll really enjoy it, other times you’ll come inside and search the interior for a new hobby. But I’m telling you, there is no hobby as satisfying as this one! |
Lo-Fi Version | Time is now: 17th June 2024 - 03:21 AM |
