> 914World Classifieds Rules
> WTB: Hydraulic Clutch Kit/Parts for 901, Anyone have a hydraulic clutch system or parts?
apexhound
post Jan 31 2023, 11:15 PM
Does anyone have a hydraulic clutch kit (or parts) for a 901?
I’ve had enough of breaking/replacing cables (IMG:style_emoticons/default/driving.gif) / (IMG:style_emoticons/default/headbang.gif) , suggestions welcome!
Thanks!!!!
Replies(1 - 4)
B2524
post Feb 1 2023, 11:35 AM
It's a sickness.
QUOTE(apexhound @ Jan 31 2023, 09:15 PM) *
Thanks!!!!
Most VW shops carry a kit that you can adapt.
Superhawk996
post Feb 1 2023, 12:06 PM
If you have cables that are repeatedly breaking, you most likely have a bad or missing ground strap between the body and the transmission.
When that ground is missing or too high of resistance, the clutch cable becomes the ground for the starter motor and drawing high current though the steel cable leads to it breaking.
apexhound
post Feb 1 2023, 09:50 PM
QUOTE(Superhawk996 @ Feb 1 2023, 10:06 AM) *
Thanks Hawk,
Great/amazing suggestion - I’ll check the strap. I’ve had a lot of flex in that region of the car, bending exhaust pipes and muffler mounts! I’m running semi-rigid transaxle mounts with a stiffly sprung pressure plate and an aggressive driving style around the cones… the cable takes a lot of tension/cycling - I can imagine if it’s acting as a ground strap too, it’s bound to fail repeatedly!
Dominic
post Feb 4 2023, 04:43 PM
Dominic
I recently picked up a gearbox that had this Hydraulic slave cylinder attached. I have no idea if it works. Make me an offer if you are interested.
Thanks,
Dominic
- Lo-Fi Version Time is now: 22nd September 2026 - 01:17 PM
