| pgollender |
Feb 7 2023, 08:50 PM
Member ![]() ![]() Group: Members Posts: 201 Joined: 5-July 11 From: Sacramento Member No.: 13,281 Region Association: Northern California |
Who makes a good remote trunk release for the 914? Any emergency release like the early Boxsters?
| 914werke |
Feb 7 2023, 10:38 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,746 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
A "good" one... no such thing.
| 76-914 |
Feb 7 2023, 11:02 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,964 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
There are 12v trunk solenoids that open them remotely. As in a momentary switch mounted under your dash. (IMG:style_emoticons/default/beerchug.gif)
| barefoot |
Feb 8 2023, 04:36 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,548 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States
I attached a heavy gauge wire down thru a hole in the trunk floor
(with small grommet) accessible behind the muffler. |
| NARP74 |
Feb 8 2023, 05:14 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,565 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
| Craigers17 |
Feb 8 2023, 05:41 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 903 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States
Down and dirty, cheap & easy. The hardest part is drilling through the latch....it's some of the hardest metal I've ever encountered. Needs heat shrink to replace the black tape, but you get the idea.
| pgollender |
Feb 9 2023, 01:35 AM
I attached a heavy gauge wire down thru a hole in the trunk floor (with small grommet) accessible behind the muffler. My previous Boxster had a,complete electronic failure and both frunk and trunk electronic latches were inoperable. The factory is supposed to put a manual wire that is accessed thru the right front turn signal lens and near the left taillight assembly,but they were both missing in mine. It was quite a bitch to get them open. Luckily a few other Boxster owners with similar problems figured a hack which (barely) worked. After fixing the electronic failure, I inserted the missing manual cables. Lesson learned…. Never again. |
| 930cabman |
Feb 9 2023, 06:00 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,824 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
Anyone have ideas/pics for an emergency release for the frunk?
| Superhawk996 |
Feb 9 2023, 07:37 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,046 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Between this and @“r towle” thread on the 997 Frunk latch I’m (IMG:style_emoticons/default/av-943.gif)
When did American’s get so lazy that pushing (or pulling) a manual trunk release just became too much to ask? |
| sb914 |
Feb 9 2023, 08:12 AM
Surf Guru ![]() ![]() ![]() ![]() Group: Members Posts: 4,686 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California
Between this and @“r towle” thread on the 997 Frunk latch I’m (IMG:style_emoticons/default/av-943.gif) When did American’s get so lazy that pushing (or pulling) a manual trunk release just became too much to ask? There used when installing a aftermarket rear reflector. Otherwise you drill a hole in the reflector for the trunk lock. |
| Superhawk996 |
Feb 9 2023, 08:33 AM
Between this and @“r towle” thread on the 997 Frunk latch I’m (IMG:style_emoticons/default/av-943.gif) When did American’s get so lazy that pushing (or pulling) a manual trunk release just became too much to ask? There used when installing a aftermarket rear reflector. Otherwise you drill a hole in the reflector for the trunk lock. Yup, I remember those reflectors and solenoids from the 80s. Was a bad plan then and still is. Drill the hole and be done with it. 40 years later and people still getting locked out of their own trunks (IMG:style_emoticons/default/av-943.gif) |
Lo-Fi Version | Time is now: 15th September 2026 - 07:12 AM |
