> heater cable question
jmargush
post Feb 8 2023, 04:17 PM
I need to fabricate a heater cable due to running Tangerine Racing heat exchanger.
Does anyone know what gauge of wire the cable is and is there a certain type of steel wire that I should be looking for?
Replies(1 - 4)
ChrisFoley
post Feb 9 2023, 09:21 AM
I am Tangerine Racing
QUOTE(jmargush @ Feb 8 2023, 05:17 PM) *
If you want to replace the cable, you should use music wire, around .045-.050" dia. However if your original cable is in usable condition it's within a couple inches I think, to reach the new position of the flappers.
I was taught a simple method to extend a too short flapper wire is to add a long small diameter cotter pin as an extension, with the cable secured around the loop of the pin.
I have a small roll of .051" music wire here. I'd be happy to send a suitable length to you to make a new cable.
jmargush
post Feb 9 2023, 06:21 PM
Thanks Chris
I'll get back to you once I know what length I need. I'll do some digging to see if I can find my old cable and see how close it is
bbrock
post Feb 10 2023, 09:48 AM
Original cables are still available from Porsche. Pricey, but are correct stiffness, are plastic coated to glide better in the tube, and have terminals crimped on for a solid fit in the barrel connectors on the flappers.
NARP74
post Feb 10 2023, 10:24 AM
914Rubber has them as well
- Lo-Fi Version Time is now: 7th November 2026 - 10:15 AM
