jeff |
Member ![]() ![]() Group: Members Posts: 255 Joined: 17-January 04 From: thousand oaks,ca Member No.: 1,570 ![]() |
Any recommendations on which cable to purchase? The prices vary quite a bit .
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,187 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
mgphoto |
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,375 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California ![]() |
Any recommendations on which cable to purchase? The prices vary quite a bit . Terry cable, double braided, unlike standard cable which will snap all at once, double braided will snap a few strands at a time giving lots of warning, lasts much longer than standard cable, pricey though. |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,189 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Beware that the Terry cable maybe TOO long. Not sure if they have corrected that problem. If you go that route compare length BEFORE installation.
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,908 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
buy a six gemo..
JamesM |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,100 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
Beware that the Terry cable maybe TOO long. Not sure if they have corrected that problem. If you go that route compare length BEFORE installation. Terry cables also lack the cable sheath that runs inside the tunnel. Given the potential of the cable rubbing directly on the guide tube every time you step on the clutch along with the near impossibility of completely replacing the clutch tube I went back to using the stock design cables. Gemo, Colfe, OEM Porsche etc. |
jeff |
Thank you all for the help
Lo-Fi Version | Time is now: 9th July 2025 - 04:05 PM |
