WTB ASAP Decel Valve for a 1.8 |
rick 918-S |
Mar 7 2023, 07:26 AM
Hey nice rack! -Celette Group: Members Posts: 20,473 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Need this ASAP for a friend. His 16 year old daughter is resurecting a fire damaged 74-75 1.8. Anyone have one of these?
Attached image(s) |
sportlicherFahrer |
Mar 7 2023, 07:56 AM
Nothing to see here. Group: Members Posts: 1,088 Joined: 18-April 05 From: Tacoma, WA Member No.: 3,945 Region Association: Pacific Northwest |
I bet @914werke has one. Believe '74 used the same as the Djet cars, and '75 went to that larger one. Different hose sizes and fittings between the intake tube and the valves from year to year.
Van B |
Mar 7 2023, 08:22 AM
Senior Member Group: Members Posts: 1,612 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
Yup. That is specific to cars with EGR i.e. 75 but not 74. Also the 76 912E would have the same valve. recommend pulling the PN from the PET and doing a search. I'm sure there are some out there still.
StarBear |
Mar 7 2023, 10:50 AM
Senior Member Group: Members Posts: 1,906 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
Need this ASAP for a friend. His 16 year old daughter is resurecting a fire damaged 74-75 1.8. Anyone have one of these? Good for her! Next next generation of teeners ( pun intended) arising. (IMG:style_emoticons/default/cheer.gif) |
Geezer914 |
Mar 7 2023, 12:04 PM
Geezer914 Group: Members Posts: 1,433 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Unless you want to be 100% original, or live in CA, you can eliminate the Decel valve.
rick 918-S |
Mar 7 2023, 02:33 PM
Thanks all. They have it bypassed for now so it is running.
ClayPerrine |
Mar 7 2023, 02:38 PM
Life's been good to me so far..... Group: Admin Posts: 15,502 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
rick 918-S |
Mar 7 2023, 03:40 PM
Thanks all. They have it bypassed for now so it is running. Great news. So the FI stuff was OK? Clay Yes, they have it running now. the biggest issue they could not get past was the connection at the controller. There is an issue where it does not like to be stressed. So likely corrosion or a small wire repair. and it seems to be sorted. It would start and run rich until it ran out of fuel from the cold start then die. Just stumbled on to the touchy connection. |
Lo-Fi Version | Time is now: 1st June 2024 - 02:05 PM |
