> 25Amp Relay Board Fuse, Relay Board Amp fuse
tbone1819
post Mar 9 2023, 11:40 AM
Hey all,
Just wondering if any of you have run into the 25A relay board fuse blowing. I've had the fuse go twice after taking the car on a good run and after the car has completly cooled down. What ground could be bad? Where should I start?
Replies(1 - 5)
914Sixer
post Mar 9 2023, 11:55 AM
Check floor heater lever.
ejm
post Mar 9 2023, 12:29 PM
I can see the light at the end of the tunnel
That fuse powers the heater fan, fuel pump and aux air regulator. I would look closely at the aux air regulator wiring. I could have broken insulation and be touching the case or the wire could be touching right where it enters the regulator.
dr914@autoatlanta.com
post Mar 9 2023, 12:56 PM
The 25 amp relay board fuse blowing on an MPC car could be caused by the fuel pump running too hot and old, the aux air valve or the heater aux blower fan. all are on the same circuit
QUOTE(tbone1819 @ Mar 9 2023, 10:40 AM) *
Hey all,
tbone1819
post Mar 9 2023, 04:07 PM
QUOTE(914Sixer @ Mar 9 2023, 12:55 PM) *
The lever itself?
914Sixer
post Mar 9 2023, 06:41 PM
Lever has green wire (12v) connected at the base. Raising the lever completes the circuit to turn on blower fan in engine compartment. Check relay board bottom for corrosion, check fuel pump relay.
- Lo-Fi Version Time is now: 7th December 2025 - 12:58 AM
