> 914-4 stub axle specs, what are the 4 x 130 bolt stub axle specs?
pgollender
post Mar 11 2023, 11:12 AM
A couple of questions:
What are the 914-4 4 x130 bolt pattern stub axle specs for our cars?
Not sure what came with my roller.
I measure 93mm O.D. on the outside flange of the stub axle with 36 spline count.
I want to keep my rims with the original 4 lug pattern, but am undergoing an engine swap with much more HP and torque. So in reading all the threads with 100mm or 108mm CV's which what the 5 lug hubs guys are talking about, these won't match up with what i have currently. Are these 93mm stub axles not stock? What am I missing here? Attached Image Attached Image Attached Image Attached Image Attached Image
Replies(1 - 3)
914Sixer
post Mar 11 2023, 03:46 PM
You have stock parts. There is NO upgrade stub axles that will work with the stock 4 bolt pattern. You have to go to 5 bolt 911 type rear hub to get 100mm or 108 CV joints.
windforfun
post Mar 11 2023, 05:26 PM
(IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif)
Protect those feet!!!
pgollender
post Mar 11 2023, 08:04 PM
QUOTE(914Sixer @ Mar 11 2023, 01:46 PM) *
(IMG:style_emoticons/default/headbang.gif) Grrr! Taylor Racing may have a 94mm high torque CV + 4 bolt stub axle solution. I've contacted them. Thanks for pointing out my inexperience.
- Lo-Fi Version Time is now: 3rd August 2026 - 01:38 AM
