| jim_hoyland |
Mar 11 2023, 03:57 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,034 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
Did the 6s come with the rain tray ?
| bossboy302 |
Mar 11 2023, 04:01 PM
Member ![]() ![]() Group: Members Posts: 88 Joined: 13-December 21 From: NorCal Member No.: 26,158 Region Association: None |
No, they did not. Wouldn't clear air filter housing.
Wow, after all the help I GET, I finally get to GIVE.... |
| mepstein |
Mar 11 2023, 04:05 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,534 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
914-6 used an air filter housing (similar to 911’s) to keep water out of the carbs.
Attached thumbnail(s) |
| fixer34 |
Mar 11 2023, 05:10 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,399 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest
| bossboy302 |
Mar 11 2023, 05:28 PM
914-6 used an air filter housing (similar to 911’s) to keep water out of the carbs. Yep, similar to this but different snorkel shape without the hose connection. curious...why not the hose...was for warm air on 911s, right? Or crankcase breather? |
| fixer34 |
Mar 12 2023, 02:50 PM
914-6 used an air filter housing (similar to 911’s) to keep water out of the carbs. Yep, similar to this but different snorkel shape without the hose connection. curious...why not the hose...was for warm air on 911s, right? Or crankcase breather? The -6 air housing had a crankcase breather fitting on the backside of the airfilter section. would have been too difficult to connect on a 911 (not that it's easy on the 914..) |
| rhodyguy |
Mar 12 2023, 02:58 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Good pictures. I see the Y, the case vapor draw off is pre air filter? How difficult is replacing the filter element(s)?
| RARE 6 |
Mar 12 2023, 03:58 PM
Member ![]() ![]() Group: Members Posts: 141 Joined: 18-January 15 From: Grand Junction CO Member No.: 18,337 Region Association: Rocky Mountains |
| Root_Werks |
Mar 12 2023, 06:27 PM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,913 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
I would love a low profile rain tray for a six. My CIS gives me about an inch at the tightest part.
| fixer34 |
Mar 12 2023, 07:30 PM
Good pictures. I see the Y, the case vapor draw off is pre air filter? How difficult is replacing the filter element(s)? Piece of cake. Unsnap the hold down clips on the carb shrouds, lift slightly so you can reach in and pull off the breather hose coming from the oil tank and take it out. Loosen 2 wing nuts holding the snorkel, twist slightly and pull off. Filter right there. Breather is actually post air filter. There is also a small drain hose on the bottom of the filter housing that vents to the outside (you can just barely see it to the right of the Y). Rain tray? I don't think there is even an inch from the top of the housing to the engine lid. Anything you try to put on there is going to cut airflow to the engine and cause it to overheat. The six draws a lot more air than the 4. |
Lo-Fi Version | Time is now: 13th March 2026 - 09:14 AM |
