> Is this a transmission drain plug?, Need help
AzGuy238
post Mar 13 2023, 02:48 PM
I'm changing the oil in my transmission of my 1974 914 2.0. Never done this before. What is this plug? Is it another drain plug or what? Its at the bottom of the transmission just near the transmission rod/forks boot? Thanks, Wayne
Replies(1 - 7)
brant
post Mar 13 2023, 02:51 PM
No sir.
That is the detent package of balls and springs
Do not remove it
The drain and fill are both 17mm Allen head screws
ndfrigi
No sir. It is on the side.
Before draining the transmission oil/gear oil, make sure you can also open the fill plug.
Root_Werks
post Mar 13 2023, 02:52 PM
Village Idiot
No, I forget what that holds in place.
Look for a 17mm Allen bolt.
AzGuy238
post Mar 13 2023, 02:55 PM
QUOTE(Root_Werks @ Mar 13 2023, 03:52 PM) *
Thank you all for your comments....sure glad you guys are all here to help a NewBee! Wayne
r_towle
post Mar 13 2023, 03:01 PM
Custom Member
Side of transmission, passenger side.
Look for two 17mm Allen head bolts
Remove the top one first to ensure you can fill it.
Then remove the bottom one to drain it.
Fill until fluid comes out of the top filler hole…that is full.
Rich
DaveB
post Mar 13 2023, 06:28 PM
Here's a picture of plugs just partially in-place while I was working on the transmission.
1/2" Drive 17 mm Allen Socket. Torqued to 18 ft lb.
DaveB
904svo
post Mar 13 2023, 07:57 PM
904SVO
Items markAttached Image
- Lo-Fi Version Time is now: 7th July 2025 - 01:28 AM
